G35 auto trans replacement
Old Apr 12, 2020 | 10:06 AM
QUEEBAN VEVO's Avatar
g35
Can I use an transmission auto from an 03 and put it in an 05 without replacing the ecu would it correspond with my ecu
Old Apr 12, 2020 | 11:15 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The ECU won't care, the TCM will. There are essentially two types of transmissions in the V35 G, one has a single large grey harness /green connector on the side of the transmission, the other has 2 green small harnesses and one small black harness.
As long as you get the correct style it will plug right in and work. If you get the OTHER style then you need to remove the valve body / TCM from your existing transmission and use it in the donor.
Some folks have mentioned needing to get the TCM reprogrammed at Nissan but that might only apply to NEW TCM's not to used ones.
Old Apr 12, 2020 | 11:17 AM
cleric670's Avatar
BANNED!!!
Also, this subforum is for WEBSITE SUGGESTIONS, I'll move your thread to the appropriate subforum, please watch for this in the future.
