Camshaft sensor oil seals
Old Dec 21, 2021 | 12:38 AM
Kris4655's Avatar
G35 coupe
So i got myself a 03 g35 coupe, it was mistreated but slowly but surely its coming back up, so my issue and request for knowledge is for the camshaft oil sensor seals, they appear to be like o-rings, the previous owners were irresponsible and put AC o rings on the camshaft sensors, causing my g to shmoke an stink, i cant find the part online, id appreciate the help, thanks g community!
Old Dec 21, 2021 | 04:19 AM
Scorpi0's Avatar
Any auto parts store should have em.
Old Dec 21, 2021 | 04:20 AM
Kris4655's Avatar
G35 coupe
So i thought, neither oreilys nor AutoZone has it, hence why i asked on here
Old Dec 21, 2021 | 01:41 PM
Scorpi0's Avatar
Well maybe they dont have an O-ring specifically for the sensors. But any O-ring should work if its the same size.
Old Dec 21, 2021 | 08:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You're not going to find specific "cam sensor o-rings", just get some EPDM or nitrile O-rings that fit snug. The viton o-rings for AC systems would have worked fine but they were probably not sized correctly, they are more expensive than nitrile which is why they're generally not used for that application.
EDIT: Don't use generic RUBBER o-rings for plumbing. Those are designed for water only and will swell/melt when soaked in oil.
Jlee133541
Mar 2, 2019 02:05 PM
Rclatter
Dec 17, 2016 07:57 AM
cpufreak3
Jun 24, 2016 12:32 AM
A to G
Oct 25, 2014 02:46 PM
