stalling problems (tried alot, vids included)
Old May 3, 2023 | 12:06 PM
zike.vq's Avatar
G35 coupe, 6spd
has anyone had issues with stalling related to the oil galley gasket? ive done pump, injectors, plugs, smoke tested and no leaks, and replaced an evap solenoid but still my idle falls too low sometimes after a rev and stalls out at lights/stops. no check engine light no codes. happens more often coming to a hard stop from high 2nd or 3rd and above. been down for a while tryna figure this out
Old May 3, 2023 | 09:26 PM
G2B35AGN's Avatar
No videos. Upload to YouTube then copy and paste the link here.
Old May 4, 2023 | 03:52 PM
zike.vq's Avatar
G35 coupe, 6spd
my bad i forgot to attach
https://youtube.com/shorts/RROk63mFnXg?feature=share
Old May 5, 2023 | 09:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I think you need to smoke test for vacuum leaks.
Old Jun 20, 2023 | 07:46 PM
Bfehr's Avatar
G35x
Any luck fixing this. I'm having similar issues and have replaced the plugs, coils and injectors already.
Old Jun 20, 2023 | 09:22 PM
zike.vq's Avatar
G35 coupe, 6spd
car finally backfired on me and stalled to a stop coming into work, i have another post about it, but basically bad throttle body i think. this was most likely warning signs of that in the long run looking back on it. no sel codes ever though. i only knew because this time it wouldnt start back up consistently until i switched out the tb with one i had in the junk pile and it fired right up and stayed on. makes sense though cause it was a used tb to begin with, might be worth buying a new one or upgrading to the 75mm just for longevity anyways knowing this now
zike.vq
May 5, 2023 01:07 AM
freegame
Jul 1, 2022 11:42 AM
andrewl_v35
Drivetrain
Dec 22, 2019 09:06 PM
Bmurphy380
Oct 27, 2016 04:09 PM
DanielsG
Mar 1, 2013 01:06 PM
