P2A00 & P2A03 Engine Codes On Simultaneously
Old Aug 30, 2023 | 06:50 PM
aidanraidan's Avatar
STILLEN Supercharged Infiniti G35 Coupe
Hello all! As I was driving to work today, my "service engine soon" light came on. After arriving to work, I scanned the codes and got a P2A00 code (A/F Sensor 1, Bank 1) and a P2A03 code (A/F Sensor 1, Bank 2). I then proceeded to clear them and haven't driven the car since (will update if the light comes back though). The car is running and driving fine, haven't noticed anything aside from the car is taking a bit longer to start than usual, but I also just hooked up an aftermarket sound system, which I assume is causing a slight battery draw after sitting for a day or so and therefore making it harder for the car to start. After searching the forums, I found a very long thread about this issue, but no one seemed to have a straightforward answer. If anybody know what causes these codes, how to fix them, or a just a general idea or list of things I should check in order to get these codes to go away it'd be greatly appreciated. Thank you in advance.
cyrus32
Jun 23, 2015 05:56 PM
aa2033
Sep 21, 2014 04:22 AM
Xet
Northern California
20
Jul 31, 2008 07:10 PM
Xblackg35X
Apr 6, 2007 10:08 AM
Kuneff
Mar 27, 2007 10:03 AM
