G35 Rattling sound
Old Jan 7, 2025 | 04:14 PM
_AquaBullit_'s Avatar
Premium 2005 G35 Coupe 5AT
G35 Rattling sound
Please help! It’s sounds sort of metallic it would come & go but now it’s here to stay Idk what it might be? Car drives normal but I’m scared it might blow so it’s just parked for now if anyone know what this sound is help plz
File Type: mov
Old Jan 7, 2025 | 04:34 PM
Revved
This is what it sounds like when revved
File Type: mov
Old Jan 8, 2025 | 07:34 AM
Scorpi0's Avatar
Hmm thats hard to tell with just a short little video clip.
What area is the sound coming from?
Old Jan 9, 2025 | 08:10 PM
It wouldn’t let me post the full videos, too big. I can send them to you though. It’s hard to tell where it’s coming from but it’s forsure from the engine Bay Area not the exhaust or anything like that
Old Jan 9, 2025 | 08:23 PM
G2B35AGN's Avatar
You can upload them to YouTube. Paste the URL here.
Old Jan 9, 2025 | 08:41 PM
Here’s the full video: https://youtu.be/k0MjNrEqSTI
Old Jan 10, 2025 | 04:09 AM
Scorpi0's Avatar
Hmmm. Bad pulley maybe? Are your spark plugs tightened down all the way? How does the serpentine belt look?
U sure u have enough oil in the engine? These engines burn a lot of oil pretty fast.
Old Jan 10, 2025 | 06:22 PM
Engine definitely has oil but I topped it up just in case because it was at the half mark, noise was still there so I pulled all the spark plugs they looked okay & i tightened them up. Noise is still there. The serpentine belt actually squeals on startup & when Im driving sometimes so that can be a possibility but then again it’s been squealing for a while & this other sound just showed up…
Old Mar 4, 2025 | 11:57 PM
Bump
Old Mar 10, 2025 | 08:11 PM
srv2nv's Avatar
G35 Sport
Check your belts and pulleys. You said your belt has squeaked for a long time? Check to make sure you don't have a worn mark in it. I would even remove both belts, inspect them for cracks and wear, replace if needed, and then check all your pulleys before putting it back together.
Your only other option is to grab a stethoscope or long screw driver and start poking around to find where the noise is coming from.
Katsuhi
Sep 26, 2023 09:43 AM
