G35 Recent Engine Swap - Stalls when it comes to an Idle
Old Sep 3, 2025 | 10:44 PM
BInfinitiG35's Avatar
Hello,
I have a 03 G35 Automatic . Recently installed a new engine (mine threw 3 pistons lol). I got everything put together took a bit for it to get started and once it did it reved up all cylinders firing then when it comes down to an idle the car starts misfiring than stalls
I got 2 Codes
- Knock Sensor
- CAN COMM
Im replacing the knock sensor tmrw but if that doesn’t work i’m at a lost. I’ve checked fueling , spark and air and nothing seems off. All grounds are connected. Just need some help w this!
(Also there’s a bit of a leak at the headers to my test pipes could that cause a stall on idle?)
Old Sep 9, 2025 | 08:34 PM
MaLPoPieS's Avatar
Jaguar XFR-S
I'd start checking all grounds, vacuum lines and gaskets (intake, t-body), PCV system and perform ECM reset. I'm not sure if your engine also requires throttle body relearn like my 07 does..
Minor exhaust leak won't affect engine performance like that..
Old Sep 10, 2025 | 10:13 AM
Ya i’ve sadly done all that, going more into it once the car gets warm (from me starting all the time) it decides to work fine doesn’t stall and idles fine but if it’s cold it’ll just die.
Ive had two codes pop up for
(P0011) Bank 1: Camshaft Position Timing over Performance
(P0021) Bank 2: Camshaft Position Timing Over Performance
​​​​​​​Not to sure at this point
Old Sep 10, 2025 | 05:27 PM
MaLPoPieS's Avatar
Jaguar XFR-S
Check this Reddit post: P0011
Hollipeter
Jul 15, 2025 01:13 AM
Rav5master
Jun 21, 2018 08:49 AM
Jacobk4508
Feb 11, 2017 12:13 PM
Jacobk4508
Feb 7, 2017 12:08 PM
Wrathernaut
Nov 17, 2011 07:06 PM
