Do I have to drill a hole in the firewall?
Hello,
Quick question: What is the easiest way to access the firewall and run some wire through it, without drilling a hole? I'm just sending the question out there, before it comes down to me putting holes in the firewall. Thanks people.
Garrick
Garrick
Inside the battery compartment is a rubber
wrapper around the ECU harness, you can poke wires through and maintain a seal.
Outter rubber pieces can also be pierced to bring wires into the compartment
while maintaining seal.
You do have to pop apart the battery cover, and the cowl lip under the wiper area
BradMD_96
Oct 6, 2015 09:31 AM
