shaky/fluctuating idle after installing the Kinetix Plenum
Old Apr 12, 2005 | 08:52 PM
ireloaded9's Avatar
The problem has to do with the car idling in the low rpm range, 200 to 500. This started to occur after I installed the plenum Sunday afternoon. I popped the hood and there seems to be air coming from the plenum. Is this normal? Did I f*ck up the install or is this normal? Everything seems to be normal while I'm driving.
Old Apr 12, 2005 | 09:11 PM
Sickone's Avatar
you have an intake leak !!! bad bad bad....
You either have a defective plenum, or you screwed up the install.
Recheck your install... did you put all the bolts and hoses back ?
Did you torque it correctly, etc....
The rough/low idle is a result of air being sucked in that the engine doesn't know about... i.e. it didn't come in through the intake so it is not giving the proper fuel.
You can isolate the leak with a sray can of something like cold start spray from the auto store... (stuff is flamable so be careful).
But if you spray a little in an area and the idle jumps up/smooths out... that is where the leak is.
jsimonk
Dec 22, 2023 03:49 PM
NohoG35revup
Aug 22, 2015 12:13 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
RA102223
Aug 15, 2015 09:24 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
