Just curious if anyone can give me more info
I was wondering if anyone has switched out their rearview mirror for another one, or has even replaced or messed with their rearview mirror. I found a couple of threads on fixing rattles, but none on switching the mirror out. My questions are:
1) How do I take the mirror off? I noticed its mounted on the glass and I didn't see any screws.
2) If I take the mirror off and try another mirror, can I put the stock mirror back on without a problem?
Thanks for your help.
I found (on other cars) that once you remove the mirror and glue it back on, even a pro, can't make it stick/look like it did before. So keep that in mind!
Originally Posted by WRAH
The mirror just breaks right off, with force. Its glued to the glass.
Originally Posted by GoSooners
My mirror wasn't glued! It was attached via torx screws. I think I used a T20. Put it back, and it's the same as stock.
I believe it's on the glass. The base slides on over a bracket that is attached to the glass. I can't confirm it today because my car is at the dealer for service but I'll take pics or something when I get it back.
I'm actually doin it to add a mirror with a monitor on it. Theres two choices of a clip on and a replacement. I'm just afraid the clip on will look bad. Whatcha think?
HeyAsianKid
Intake & Exhaust
Oct 7, 2015 01:55 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
) Anyway, its really big and I don't know how I got along without it. [IMG]
