Is there any reason for me to do the Technosquare thing...
Old May 26, 2005 | 11:55 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
Is there any reason for me to do the Technosquare thing if I'm already in the habit of running 93 octane fuel?
I've been told that I would see little/no benefit from it.
This has come from two very reliable sources (but I don't want to throw them under the bus, so I won't list them).
Get a cup of coffee and let's discuss this
Old May 26, 2005 | 11:58 PM
ChazM's Avatar
well you only have intake, which pretty much just makes noise.....so why would you?
Old May 27, 2005 | 12:02 AM
jnkirk1974's Avatar
Because I have Crawford cats and a plenum spacer on order right now.
Old May 27, 2005 | 12:11 AM
roneski's Avatar
Devil's Advocate
It depends on what your A/F curve looks like. After my mods mine was pretty good. Around high 13s until just past 6000 rpms when it dipped into the 12s, but I was ok with that because to me it translates into safe reliable power. So I didn't have them mess with any of my fuel or timing maps, I just got their L-spec reflash which gives you the raised rev limiter, removes the speed govenor and opens the throttle body 100% whenever you floor the pedal.
If your air fuel ratios are lower then there is power to be had from them adjusting your maps and timing to lean it out a bit.
