Engine Upgrades=GAS? noob questions
Old May 30, 2005 | 12:21 PM
cutiewolf's Avatar
OK sorry,i know this has been discuss before ,but just couldn't find any pervouis post ,
the mod im odering is
Z-Tube/ JWT POP, UR CRANK PULLY
hyper ground wires,stabilizer/Hyper Voltage
where to purchase 3/8" Motordyne Spacer?wat exact does it do?
which of these burn up GAS THE MOST?
i live in nyc yeah the gas is too expansive!for a daily driver! i dont really wanna upgrade anything that burn up alot of gas
ok ppl..after reading this plz dont smack my head...any opinions?help me
Old May 30, 2005 | 02:36 PM
WolfsterX's Avatar
I would say the combination of Z-Tube and JWT will most like burn gas. I never had the UR Pulley so i can't say much about it.
Getting the ground wires and Hyper voltage may improve gas mileage.
Old May 30, 2005 | 02:46 PM
GZire's Avatar
None of those parts should decrease your gas mileage.
Old May 30, 2005 | 06:25 PM
cutiewolf's Avatar
i know for sure now ground and Hyper Voltage they do save up gas mileages.
wat about the spacer?
z-tube /w POP or K&N drop which combo burn up the gas quicker?
RU CRANK PULLY?
Old May 30, 2005 | 08:50 PM
sushmaster_g35's Avatar
intake/spacer will increase mileage...that is if you don't floor it everywhere because of the nice sound
Old May 30, 2005 | 09:28 PM
cutiewolf's Avatar
cool thx alot...wat about the oil pan spacer,and the UR CRANK PULLY?
Old May 31, 2005 | 01:53 AM
GZire's Avatar
The spacer increases the upper intake manifold (plenum) volume and makes it easier for the engine to breathe especially at higher rpms. Do a search on "spacer" and you'll be able to find where to buy one.
Z tube, JWT, K&N are all supposed to make our engine breathe easier. The only way I see these affecting gas mileage is the JWT which might be taking in hot air from the engine compartment (at low speeds and even more so in city traffic) because their heat shielding is not the greatest.
Grounding kits are supposed to clean up electrical signals and help your car run a bit smoother. There benefits are probably not going to be seen on a manual, but more so on an automatic transmission (though I am sure there are some who will swear by them).
I don't see a reason why to get an oil pan spacer unless you will be racing/tracking your car and you'd still want to look at other things before this.
Changing pulleys to under-drive whatever is not a good idea. Yes I realize people do this, but if you are in the city why do you want to under-drive something like an alternator?
The single biggest factor in your gas mileage is where & how you drive. City driving just kills the gas mileage on the G and none of your mods above are going to make any significant change to your gas mileage.
jsimonk
Dec 22, 2023 03:49 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
richmc
Jul 26, 2015 08:13 PM
