Quickest Way To 300hp... Question
Old Jun 12, 2005 | 11:16 PM
JEVERYDAY's Avatar
Heys guys, somewhat of a newb here... Been searching alot about upgrading and parts through the forums, didnt see this already posted...
Basic question or not too basic...
What is the quickest way to 300HP? Would I be there with soley a JWT Popcharger and Z-tube, or would i need other upgrades... Probably a newb question and extremely Non-technical but hey I wny know if I dont ask.
Thanx guys, this forum is such a big help.!
P.S~~~> Should we be able to atleast tail a Lacer EVO?
Old Jun 12, 2005 | 11:30 PM
WRAH's Avatar
WRAH
SC or ST, or TT
Old Jun 12, 2005 | 11:39 PM
Basheer's Avatar
Call the Cops
the pop charger/z tube combo shouldnt be put on for horsepower increase.. just the sound...
1. exhaust ( HKS )
2. Cats ( Crawford )
3. Plenum Spacer ( Motordyne)
4. UR Pulleys
im pretty sure these mods will get you over 300hp.. so research them and give them a try. they arent too expensive except for the exhaust.. will run you about 2800
Old Jun 13, 2005 | 12:19 AM
Jeffjett's Avatar
Enthuasiast
Buy the 05 6MT coupe. They are 298 HP.
Old Jun 13, 2005 | 04:18 AM
EricIsKlumzyee's Avatar
he might be talking about wHP
Old Jun 13, 2005 | 10:41 PM
JEVERYDAY's Avatar
I already know that ... But I have a 05 AT GCoupe
Thanx
Old Jun 13, 2005 | 10:50 PM
Fooboy's Avatar
I'm with you Jeveryday! I also have the 05 AT Coupe. I've been constantly wondering how the hell I can get 20hp!!! Will a catback alone be able to do it? Or do i have to spend more cash on intake-headers-exhaust? I know what the functions are of each part, but how much power can I get from each?
foobs
Old Jun 14, 2005 | 12:42 AM
WRAH's Avatar
WRAH
Aren't we around 240whp stock??? You have to do more than breath the engine.
300whp or at the crank?
Old Jun 14, 2005 | 12:55 AM
Fooboy's Avatar
280
Old Jun 14, 2005 | 01:17 AM
escobar929's Avatar
think theyre talking bout crank, if you guys are then you'll need:
intake
headers
highflow cats or test pipes
catback exhaust
a lil luck
Old Jun 14, 2005 | 11:57 PM
636Racer's Avatar
I'd say go hardpipe intake, exhaust, fuel (pump and injector upgrade), and a ECU piggyback and a tunning session or a TS ECU flash. If you want to upgrade the pulleys, do so, but leave the crank pulley alone, there's a reason why theres a damper for harmonics. otherwise you can also upgrade your pulley damper to a fluid dynamics one. There's also some cheat ways in increasing compression (if youre not going forced induction), like finding a thinner metal head gasket and shaving the cylinder head. i believe HKS may have a metal head gasket, but consult with a speedshop/machineshop to help you find one.
Intake and full exhaust may gross you about 15-20rwhp, better fuel complements and tuning may get you an additional 10-15rwhp. You might be well shy 20-30rwhp of hitting 300rwhp. From there, a quick burst of laughing gas is tried and true, and a little 50hp shot may get you that small *umph* you might need.
Old Jun 15, 2005 | 08:18 PM
JEVERYDAY's Avatar
Thanks alot fellas... I think I will start with the POP and Z tube and see if I notice a difference. From there I will move up.
My main goal is to be able to hang with A DAMN EVO and STI, even though the STI is a pretty drastic catch, i already know...
Old Jun 20, 2005 | 07:10 PM
ketch's Avatar
To end all discussion an easy way to get over 300 hp is (not rw)
Crawford Plenum
COLD AIR intake
Stillen Exhaust
Stillen Ground Wires
Pulleys and Belt set
Stillen HEaders
hks spark plugs
i think this should do it but dont qoute
Old Jun 20, 2005 | 07:56 PM
Alan's Avatar
its going to be pretty tough to hang with thoes guys without forced induction. crawford is supposedly cooking up a cam package. hopefuly they can deliver quality as they have in the past!
