Hey...
I was wondering if I removed the actuator from the throttle body with the battery disconected, when I plug everything back again, will it cause any kind of trouble? Will the car be able to start again or is there any harm I may be doing by removing the actuator?
Any info will be appreciated...
Thanks
Thanks
It should be fine...
But I just wanted to comment on your name. Very funny.
good luck Gandu...haha
Thanks
I had mine off many times (without disconnecting the battery) and it was fine every time. No worries.Originally Posted by gandu
Hey...I was wondering if I removed the actuator from the throttle body with the battery disconected, when I plug everything back again, will it cause any kind of trouble? Will the car be able to start again or is there any harm I may be doing by removing the actuator?
Thanks
BTW, welcome to G35Driver.
C.
thanks for the data...
anyway, I tried pulling it out and it was really difficult... do you remember if it has a clip or any sort of safety mechanism for release?
Thanks
What will you gain from removing the actuatorOriginally Posted by gandu
Thanks
