Grounding wires installation question
Old Jul 28, 2005 | 05:58 PM
ryanwiggum's Avatar
Question Grounding wires installation question
I received my grounding kit today and I'm a little confused with the instructions. Towards the end of the instructions, it states:
"13.) Remove the nut holding the negative (-) battery terminal using the 10mm wrench. There is no need to remove the battery terminal."
then says:
"14.) Connect the loose end of the #3 (26") wire to the battery terminal. Replace nut. Use the 10mm socket and driver to secure."
The picture doesn't show where the wire is connected to:
Where does that wire connect to? Negative terminal post? positive?
Old Jul 28, 2005 | 09:30 PM
Gordgee's Avatar
Administrator
If I'm not mistaken, that looks like Z-Xtreme's kit. If so, just connect the loose terminal of #3 to the negative terminal clamp of the OEM grounding wire. I'm not sure if his kit's lug end is ground to fit in the clamp, but if so, you should be able to fit it on either side of the clamp.
Hope that helps. If you e-mail Guyula, I'm sure he can clarify it for you.
EnCr1pt3d
Jul 8, 2019 02:48 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
