Samco Hoses
Old Aug 23, 2005 | 09:42 PM
Diesel1's Avatar
Moderator
Yes they do! Thank you very much!! I wish the PiThons came with better directions! I see you only used one fitting for the upper rad hose adjacent to the resovoir. I put both up there but I'm not crazy about it. I am certainly not draining and bleeding the system again!
Can anyone confirm that you can reuse the stock clamps on the samco hoses? I used the stock clamps for the lower rad hose going from the rad to the thermostat and couldn't pull them off so I hope they are good! If someone can confirm, I'll be a happy camper!
Thanks!
Old Aug 23, 2005 | 10:05 PM
njsfastestg's Avatar
G SQUAD
d, you can use the stock clamps except on the on the thin one that goes from the bottom to the top of the block. that s the one just above the pulleys. i tried to put the stock clamp on it and it didn t work so went to pep boys and got a set of clamps. all the others were ok.
Old Aug 23, 2005 | 10:49 PM
Diesel1's Avatar
Moderator
U Da Man Tony!! I got the PiThons for that hose!
Old Aug 24, 2005 | 11:53 AM
irony's Avatar
Tinman..can you post pictures of the pi-thons on the vacumn hoses?. I noticed that you only used one pi-thon lock on the upper rad hose, why?
Your G looks great
Old Aug 24, 2005 | 12:46 PM
TINMAN's Avatar
thanks
it was a bitch to put that on.so the guy who put them on for me left it out.he inform me about it so and said ok,i'll do it myself later.the problem is i'm so damn lazy and that's why it stay that way.
Old Aug 25, 2005 | 11:38 PM
Gordgee's Avatar
Administrator
Thanks!
You should be aware that the stock clamps, or standard hose clamps are not 'silicon hose' safe. The edge can cut into the silicon hoses, especially over time.
Highly recommended are clamps like the 'Mikalor' clamps which are higher quality (used by racing teams), and have bevelled edges to protect the silicon.
Old Aug 25, 2005 | 11:49 PM
Diesel1's Avatar
Moderator
Good call Gord, now where can u find em? I picked up a cheap set at PEPBOYS for the resovoir hose, but I may go grab those just to be safe!
Old Aug 27, 2005 | 02:29 AM
Gordgee's Avatar
Administrator
They don't have one sized for the generic silicon reservoir hose anyway. The rest of the set works great for the remaining Samco Hoses.
You may have to call around as they can be hard to find. Here're are a couple of links:
http://rallynuts.com/motorsport/contact.asp
http://www.powerengineering.co.uk/mikalor/
In Edmonton, they're available from http://www.autobraun.com/.
Old Sep 15, 2005 | 07:57 AM
KPierson's Avatar
Sorry for taking so long to post pics, but here one is. I know its kinda blurry, but you can still see how the Samco hoses really draw your eye away from everything else.
Old Oct 11, 2005 | 09:22 PM
n1cK's Avatar
G35 6MT
but that looks good kev!
Old Oct 11, 2005 | 09:31 PM
G352NV's Avatar
Never enough
I guess it just depends on what else you have done.
Old Oct 11, 2005 | 11:32 PM
n1cK's Avatar
G35 6MT
see, told ya!
ps-hey, that kinetix plenum, have you dynoed it yet? yeah, i probably should've done a search....and NO, i'm not hijacking this thread!
Old Oct 11, 2005 | 11:34 PM
G352NV's Avatar
Never enough
Not yet but Ill post after.
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
lavtxa
Sep 21, 2015 11:51 AM
G35CO
Sep 4, 2015 09:27 AM
