Will ARC oil pan fit G35X?
Old Aug 22, 2005 | 01:33 AM
ekwc's Avatar
I emailed the saleguy (Peter) at ARC, and he didn't sure about it. Could anyone here help? Thanks.
Old Aug 22, 2005 | 09:59 AM
Gsedan35's Avatar
Go to your local Infiniti dealer's parts department and see if the pan's are the same part numbers for the RWD G and the X. That will give you your answer. Oh and have your vin number and one off a RWD G on their lot cause they will most likely ask for that.
Old Aug 23, 2005 | 11:02 AM
ChicagoX's Avatar
Don't drink and Mag Race
If it is just the lower pan, it should fit. If it the whole assembly, it will not fit.
The G35X has a special pan where the front half-shafts pass directly through it.
W.
Old Aug 24, 2005 | 08:24 AM
ekwc's Avatar
Thanks. Will the extra large lower oill pan (eg: ARC, or APE) hit any thing around (eg: oil filter, or the AWD system)?
W.
Old Aug 24, 2005 | 11:29 AM
ChicagoX's Avatar
The oil filter assembly is placed on the side of the pan, so I don't see any reason for interference. Looking at the underside, it looks like the only drawback would be a small decrease in ground clearance. I was considering the JWT pan spacer to increase oil volume and they assured me it would fit. I don't know if the other pans have a different shape, but the Greddy and the JWT should fit, IMHO.
Good luck!
W.
Old Aug 28, 2005 | 10:04 PM
ekwc's Avatar
Thank you
Good luck!
W.
jsimonk
Dec 22, 2023 03:49 PM
North NJ G
Steering & Suspension
12
May 27, 2023 01:14 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
reavensf
Sep 17, 2015 11:30 PM
itztwinki3
Aug 11, 2015 05:52 AM
