Oiled Filter vs. Stock Filter Question
Old Aug 30, 2005 | 01:40 PM
dkeystone's Avatar
Question Oiled Filter vs. Stock Filter Question
Thinking about getting either a JWT Pop Charger or Stillen CAI box with K&N cone filter. I'm slightly concerned about the filter not getting out as much dirt as a stock filter. Anybody know anything about this issue? Specifically, whether using an oiled filter will allow for more dirt to get into the engine and, as a result, cause more engine wear than with the stock filter?
Thanks.
Old Aug 30, 2005 | 01:44 PM
dkeystone's Avatar
And, any suggestions between the Stillen and the JWT pop charger. I have a 2005 G35 sedan. It's all stock at this point.
Old Aug 30, 2005 | 03:08 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
The oiled filter works just as good as the stock one. Don't worry too much about it, I've used a K&N filter in every one of my cars since the early 90's.
In my opinion, oiled would probably work better, because the oil attracted the dirt.
Old Aug 30, 2005 | 04:56 PM
dkeystone's Avatar
jnkirk1974, thanks for your reply on this. Any thoughts on JWT vs. K&N in terms of quality? Are you still using the JWT popcharger?
DEK
Old Aug 30, 2005 | 05:12 PM
madchef's Avatar
Any replacement filter is going to let in more air than the stock filter....more air means more dirt/etc. If you are concerned with dirt/etc then I recommend you go for an aftermarket paper filter. Nismo has one ($$$), not sure who else. Only downside is you'll have to replace it, as opposed to "recharging" an oiled one.
Old Aug 30, 2005 | 10:02 PM
jnkirk1974's Avatar
DEK
K&N is a bigger name. However, you could flip a coin because they are both good.....really!!
Old Aug 31, 2005 | 01:38 PM
dklau33's Avatar
Give this a read. Interesting article on air filter testing.
Click Here
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
ClwMike
Jul 23, 2015 12:55 PM
