What Is This???
Old Sep 9, 2005 | 12:14 AM
Derek S's Avatar
What Is This???
what is this guys and what does it do.
Old Sep 9, 2005 | 12:34 AM
CarFanatic56's Avatar
is that the cf z-tube from UT?......is that mini red filter connected to the tube where the pvc normally connects too on the ztube?....thought i saw pics of it connected there?
Old Sep 9, 2005 | 12:57 AM
Derek S's Avatar
anybody else???
Old Sep 9, 2005 | 01:03 AM
PieroG35's Avatar
open up you hood and look at your g-tube. Their is a rubber hose that connects to it. CF tube doesn't have an inlet to make the connection. You stick that thing in as a substitute.
Old Sep 9, 2005 | 08:40 AM
glennp_1999's Avatar
Yep it's called a breather.
Old Sep 9, 2005 | 02:47 PM
P_Diddy's Avatar
who's your daddy and what does he do
Old Sep 9, 2005 | 03:56 PM
bjdraw's Avatar
By using that instead of running a tube between the CF tube and the manifold, it prevents warm are from the engine from entering the intake. But it also eliminates any vacume under the valve cover. Bottom line is your don't need the tube, and you don't want dirt getting in your valve cover and you can't plug it.
Old Sep 11, 2005 | 06:18 AM
skeleton_cru's Avatar
Sedan
I'm a cop you idiot!
