ECU update
Old Sep 13, 2005 | 08:28 PM
infilen's Avatar
Smile ECU update
Need info on how to perform ECU udate with gas pedal after performing mods? Thanks in advance.
Old Sep 14, 2005 | 09:27 PM
jbone's Avatar
'04.5 Black 6MT Coupe
Do a search, it's in the diy sec, plenty of info
Old Sep 14, 2005 | 09:44 PM
codeflux's Avatar
http://www.technosquareinc.com/350reset.htm
Old Sep 15, 2005 | 09:45 AM
jnkirk1974's Avatar
Fastest G35 In Rockwall
Just an FYI, you don't need to reset the ECU after doing your mods.
Old Sep 15, 2005 | 11:50 AM
DaveB's Avatar
Exactly. Give it a 2-3 days and the ECU will make the correct adjustments. Reseting the ECU results in lethargic performance for nearly a week until the ECU has made all it's adjustments.
Old Sep 15, 2005 | 11:51 AM
G35_coupe_6MT's Avatar
Search for "ECU Reset" there are threads with that info. Let me add that if you have an MT... then press the clutch before you even insert the key. MT cars have a little button that is pressed when you press the clutch (thats why the engine wont start if the clutch isnt pressed).
DEMoLITIoN
Interior
47
Oct 6, 2018 10:44 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
