DIY oil change question
Old Oct 10, 2005 | 08:55 AM
jimcambell's Avatar
I use ramps. I put a 24-inch 2x4 in front of each ramp to keep the lip from scratching on the ramps when I drive on. I also have an 8-foot 2x4 marked for distance between the front tires to assist with alignment before driving on. Then I pull the car onto the 24-inch 2x4's, get out and recheck alignment of the ramps, and then pull on. Never any problems if you just take the time to be careful with what you are doing.
Old Jan 11, 2007 | 05:01 PM
tdizzy35's Avatar
I recently bought an 06 sedan with 17,500 miles on it and the sticker for the next oil change says 25000. Im guessing the previous owner is using synthetic but not sure. How can I know for sure since the oil looks good to me? Also, what is recommended for the vq as far as oil and the period in which it should be changed? Ive got 20000 on the car right now and Im iching to change it just so I know its all good.
Old Feb 19, 2007 | 08:24 PM
redriderr's Avatar
Well scratch the itch! An oil change will never do harm...
Old Mar 13, 2007 | 09:05 PM
SkyBlueG35's Avatar
its so fast and cheap to have a shop change the oil and plus they guarantee the work they do
Old May 26, 2007 | 09:30 AM
kenchan's Avatar
^^ problem with that is sometimes you find scratches on your rims or
a dirty car afterwards; my dealer did mine once and did a good
job....it was a free change so just had them do it while my car was
still running stock wheels.
with my aftermarket wheels, i just do it myself.
Old Jul 17, 2007 | 02:27 PM
keen1801's Avatar
I just did the 1st oil change on my 03.5 sedan with 50k miles. I bought it with just under 43k. I had checked the oil level and condition periodically and it is amazing how the oil held up so well. My wife drives it about 80 miles per week, with most of the mileage being racked up on the weekend.
I didn't have to drive it up on 2x4 since it is still at stock height. At first I tried to jack it up from the front center but couldn't see the jack point to do it properly. I then decided to jack it up from the driver's side behind the front wheel. It went well and I didn't have to jack it up much to get enough clearance. I then put some 2x4 under the front wheel to support it in case of jack failure, but the proper way is to get a jack stand under there.
At first I couldn't see the oil filter, just the drain plug so I removed the underbody plastic, which takes about 10-12 10mm bolts. The filter was right by the drain plug. All in all it was a piece of cake. I just wasn't familiar with the car. I love how the filter is in sideways, compared to the V8 cars everyone in my family owns. It is so much easier to get it drained.
Old Jul 17, 2007 | 04:16 PM
Voodoo's Avatar
CCT-we call down the rain
Everything is pretty accessible for the DIYer.
Old Sep 18, 2007 | 03:02 AM
Scrooge's Avatar
I got the craftsman low profile alulium jack for the G35. It works great and my car is stock height. But you guys should check first the jack fits under the back. Because my old 3 ton jack I got from HF didn't fit under the back on the car because it would hit the muffler. So when I bought the low profile jack, I made sure it went under the with out no problem.
Old Sep 18, 2007 | 11:52 AM
Brando's Avatar
Cool
I use some small ramps I built out of 2x8''s and then jack it up and put it on jack stands.
I installed the Fumoto valve with the nipple that makes it very quick and no mess.
Old Sep 18, 2007 | 02:04 PM
kenchan's Avatar
very true. i only use ramps to do my oil changes. what i do is measure
the ramp to make sure it is parallel. then i park my other car next to the
car im working on so that i can use the reflection off my other car's door
to see myself go up the ramp and know when to stop.
i use to use a large mirror, but my car reflects just as good.
haven't had any incidents with this technique. use at your own risk.
Originally Posted by gary c
Using ramps can be very dangerous! A friend of mine had a custom '34
Ford Victoria. While driving on the ramp one side went off the ramp and
destroyed part of the front end........very costly! If you need to change
your own oil it might be worth it to invest is a jack that has the roller in
front. Clearance is something like 3" and will raise the car with three pumps
of the handle. Even Sears has this type of jack.
'04 G35 Twilight Blue Coupe Premium - Borla cat back - Stillen Intake -Z tube
Clear sides - 35% Tint
Old Sep 28, 2007 | 04:58 AM
imalazeeass's Avatar
never thought of doing that.. LOL. I'm always very worried i'll go off the ramps. I'll have to try that next time.
Old Sep 29, 2007 | 11:21 PM
express705's Avatar
ramps are the best. just know what your doing so nothing slips and yea.. it can get ugly if the ramps dont grip.
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
