ahh !!! please help fuse blow car fuked
Old Sep 28, 2005 | 08:11 PM
ebuy929's Avatar
hey guy,
i managed some stupid stuff again .
i was changing the leds bulbs in my headlight pipe light and the bulb kept failng out so i took tweaser and tride to tighten the gold clams holdin the bulb to make it stay. next thing i know my stipe light are not working, my corner light are out, my tailights only turn on when i brake, my licence plate wont iluminate, my headlight turning signals only work when i signal not when xenons and fogs are on, and finally my center consol has no lights..
by the way i have a coupe and the light i original tried to install where the little side stripe lights on the side of the headlights. i gues i crossed positive and negative and blew a fuse
i took it to a shop and they couldnt find the correct fuse box to check the fuses they found the one by the battery and under the drivers side . they couldnt find any other fuse boxes for the accesory lights (there was nothing under passenger side)
basicly where is the correct fuse box located.
also what do u think the problem is . a fusE? the mechaninc said its possible i messed up the relay system flasher or somthing and im fuked. ithnk its a fuse
any ideas help suggestion>?
please
Old Sep 28, 2005 | 08:18 PM
GsUpHoesDown's Avatar
say what? i hope its just a fuse...sounds ugly.
Old Sep 28, 2005 | 08:27 PM
ebuy929's Avatar
lacation
does anyone know where the fuse box is for the taillights and accessories. i found the one in the hood i found the one on the driver side but is there one on the passesnger siede i could not fdind it
Old Sep 28, 2005 | 08:46 PM
S-Tuned's Avatar
gtr proto test driver
..left side under steering wheel, dont play with it though because you dont have any luck lol
Old Sep 28, 2005 | 08:57 PM
ebuy929's Avatar
i know the left side but it doesnt have the fuse for the taillights wheres the one on the passenger side
Old Sep 28, 2005 | 09:04 PM
coupin827's Avatar
The fuse for the tailights is under the hood. I blew that one which also controls the lights for the dash/radio.
Old Sep 28, 2005 | 09:08 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
it's prolly a fuse....
i''m trying to interpret the manual as I type.... give me a sec
this one fuse connects the tail lamps, turn signal, side marker lights, and license plate
Old Sep 28, 2005 | 09:15 PM
Msedanman's Avatar
O.F. Administrator
There is another fuse box in the battery compartment, that has some relays and other fuses. The id for these fuses and relays is on the outside of the box. Check for one that's burnt.
Old Sep 28, 2005 | 09:18 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
looks like a 10A fuse located in the IPDM, which is located in the engine bay, by the battery
pull up the cover.
you'll see a bunch of relays and fuses
there should be two rows of fuses. the row closer to the passenger side has the fuse you are looking for. it is the 5th fuse from the top, #75
so it goes:
#71 10A
#72 15A
#73 15A
#74 20A
#75 10A <------- i think this is the one
i am not an electrical expert by any stretch of the imagionation. if you are competent, you can quickly check this fuse out.
if not, wait for someone who know what they are doing to chime in.
i am moving this post to the tech/mod forum since that is where you'll get more help
good luck
Old Sep 28, 2005 | 09:28 PM
ebuy929's Avatar
thanx guys ummmmm i called my friend whos brother in law is a mechaninc at lynbrook infniniti he said theres one fuse box behind the battery and one in front i cant find the one behind and if one fuse connect the clearence side and tails im so releaved now just how do i find that fuse lol and how do i check it
Old Sep 28, 2005 | 09:35 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
don't do it.
it seems you don't know what you r doing
if memory serves me correctly, there is a fuse puller in the driver side kick panel, courtesy of Infiniti.
use that to pull the fuse i mentioned above. if not, you can buy one from an auto parts stores. when you replace the fuse, MAKE SURE you replace it with a 10A fuse of the correct size.
best of luck and let us know how it works out.
the IPDM is *EDIT* in the back of the battery. it's the bigger looking one. you'll know what is when you pull it up.
take it to your friend if you don't know what u r doing.
Old Sep 28, 2005 | 09:55 PM
ebuy929's Avatar
thanx guys i just wanna confirm that one fuse is for the licenseplate tail ights center console lights corners and clearence.
and this fus eis lacated behind the batter in the big fuse box
how do i get to that rear box
Old Sep 28, 2005 | 11:12 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
champppy
Mar 31, 2020 12:25 PM
mike730
Jan 12, 2018 04:25 PM
.cakestar
Jul 28, 2015 01:57 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
beevanhuynh
Jul 14, 2015 09:06 AM
