Independent Fog light Control
Old Jul 13, 2006 | 08:12 PM
  #31
willthethrill's Avatar
Originally Posted by RocketG35
Would this module work with aftermarket fog lights - meaning adding a set of Hella fogs and bypassing the stock ones?
same question but not bypass, just in addition to the stock fogs.
Old Jul 13, 2006 | 10:40 PM
  #32
KPierson's Avatar
The module has an output that you can technically do anything you want with. For example, you could turn your OEM fog light switch in to a navi switch, or use it to drive fog lights. The output is a standard (-) output so the options are endless....
Old Sep 4, 2006 | 03:25 PM
  #33
ttrank's Avatar
Grocery getter
Count me in for one the fog light module and the mirror auto-tilt module!
Old Sep 4, 2006 | 04:41 PM
  #34
helldorado's Avatar
Any updates?
Old Sep 4, 2006 | 09:32 PM
  #35
KPierson's Avatar
I just made some software changes last weekend and everything appears to be working 100% as designed. I ordered the parts necesarry to make the fog light kit and they are in. I will probably beta test these and then they will be ready!
Old Sep 4, 2006 | 09:37 PM
  #36
Gdup35sedan's Avatar
ENVautoDetailing.com
cant wait for these to come into production!
-GP-
Old Sep 13, 2006 | 09:18 PM
  #37
destroid's Avatar
Defininitely want to try this - how do we sign up as a tester?
I think the fogs would make great DRLs. Also you could use them for flashing other cars without worrying about using the HIDs.
Of course the best part is projector HID highbeams + fogs == crazy bright.
Old Oct 7, 2006 | 12:25 PM
  #38
dovla's Avatar
Say Kevin, what is the current score? Thanks
Old Oct 7, 2006 | 02:10 PM
  #39
accordfreak's Avatar
wow can't wait... i'm going to buy all your modules at once.. do i get discount? haha roll up window/sunroof, beep beep, foglight and auto locking
keep up the good work
Old Oct 7, 2006 | 06:01 PM
  #40
KPierson's Avatar
I'm happy with the operation of the module right now. This is the longest that it has worked without a single issue.
Now, I just have to document the install process so everyone can follow it.
Thanks,
Kevin
Old Oct 14, 2009 | 06:51 PM
  #41
pythonjosh's Avatar
2 year old thread bump......
Any updates? I have done this on a 99 Solara just by rerouting some wires to manually control the fog light relay, but with this "Matrix" thing, doesn't sound as simple in the G35.
Was this project accomplished Kevin?
And why is this thread in Engine, Drivetrain and FI?
Thanks,
Josh
Old Oct 14, 2009 | 07:33 PM
  #42
KPierson's Avatar
Yes, this module has been available for quite some time now! Check out www.KPtechnologies.com for more info
Old Oct 14, 2009 | 07:42 PM
  #43
pythonjosh's Avatar
It does not show for 2003, maybe need to update the database?
I just found it for 2004, does it not work for 03?
Old Oct 14, 2009 | 07:47 PM
  #44
pythonjosh's Avatar
Correction, I found the Fog Light category when I changed the year while viewing the 03 products.
Then I change the year back to 03, and it shows the category view again showing Fog Lights.
But the initial search does not show category view, and also does not show Fog Lights.
Reporting website problems, just one of the things I do as a web designer.
Old Oct 14, 2009 | 07:48 PM
  #45
KPierson's Avatar
I updated it to reflect compatibility with the '03 coupes.
