Motordyne Plenum Spacer Install Question
Old Oct 20, 2005 | 11:28 PM
CouperDouper's Avatar
I am about to install a Motordyne 5/16" spacer and have a couple of questions. Is there any reason to worry about damaging the existing gasket when removing the top half of the plenum? Should I buy a new one to install? Is any sealer or oil needed on the gaskets? Any tricks or things to be careful when installing would be greatly appreciated. Also, Tony said not to worry about resetting the ECU when since I'm just installing the spacer. Just drive it to redline a few times after the install. I have (I think) reset the ECU in the past by removing both engine fuses, cranking the engine, waiting a few minutes and then re-installing. Any tips or advice would be great Thanks!!!
Old Oct 24, 2005 | 08:14 AM
ISMSOLUTIONS's Avatar
If you've flashed your ECU - don't worry about resetting it. Just follow the directions and everything should be fine. Also, there are easy ECU resetting threads that work grear without vattery disconnects needed - but I'd just drive it around kind of hard for about 5 minutes - the ECU will adjsut itself.
Old Oct 24, 2005 | 02:17 PM
eldy's Avatar
Here is how to do the "pedal reset" from our friends at Technosquare:
http://www.technosquareinc.com/350reset.htm
Old Oct 24, 2005 | 02:26 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
No need to change the original gasket.
Just keep thinks clean & follow the instructions.
If you're doing the complete iso-thermal (highly recommended)
then you need to oil the new iso-therm lower gasket per instruction.
Old Oct 24, 2005 | 03:08 PM
SMOKEDLEX's Avatar
i cant wait till i can get my wheels and suspension done and get my iso thermal and spacer with z tube. So excited (w crawford high flow cats and fuji exhaust)
Old Oct 25, 2005 | 11:40 AM
my_Gthang's Avatar
will the engine cover fit with the spacer?
Old Oct 25, 2005 | 12:03 PM
It's supposed to with the 5/16" one, which is why I went with it. It won't fit with the 1/2" spacer.
Old Oct 25, 2005 | 02:34 PM
Just finished my install - 20 minutes ago - 1/2" spacer and cover fits fine!
05 Coupe Auto
Old Oct 25, 2005 | 03:48 PM
SWAT311's Avatar
05 Coupe Auto
Interesting... anyone else have this outcome - the engine cover still fitting with the 1/2" spacer?
Old Oct 25, 2005 | 04:02 PM
EricIsKlumzyee's Avatar
careful.. after a while you'll notice the engine cover rubbing on the hood insulation thing
Old Oct 25, 2005 | 09:07 PM
Yes - it does touch. 2 small 1/4 inch pencil line-sized areas - about 1/32" deep...like I'll even count that?
And sorry - but careful about what? No buldge on the hood - like nothing is there, and no fire or worry? Elaborate on careful, please.
Also, I'm not going to warn about possible hood damage or rubbing on an 05 G35 Coupe - It's not an issue on this car..others and years and 350's - possibly a differnet story.
Old Oct 25, 2005 | 10:12 PM
some guys just like to keep everything perfect and scratch free..
Old Oct 25, 2005 | 11:04 PM
Nothing is scratched...just two small indentations on the under hood pad...
Old Oct 25, 2005 | 11:07 PM
OCG35's Avatar
yes, it fits... invert the grommets and it will (but snug). The rubbing on the hood liner is negligible.
If you are going to use the iso thermal kit - keep the cover off or use a Z cover (otherwise you're defeating the purpose).
Old Oct 25, 2005 | 11:18 PM
I didn't invert the grommets - stock and still looks it too...
Gip
Aug 24, 2015 05:31 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
andresito7
Aug 1, 2015 04:53 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
