Chnaging Radiator Hoses
I'm going to be installing some custom red SAMCO radiator hoses in my G35 Coupe. I was reading that of course I should drain the coolant from the radiator, but must I also so it for the engine (I looked in the ESM and the engine block has 3 drain plugs)?
No need to drain from the motor. If you wanted to get crazy, you can do a complete flush and fill, but I think it's a waste of time and money. Simply drain the coolant from the radiator (You should be able to drain about 1 gallon). Replace hoses with Samcos and refill. When I did mine, I was able to put about 1 gallon of 50/50 mix back in. I picked up some Dionized water from duane read or eckards to mix with the coolant. Regular tap water is not reco'd. The minerals in tap water will eventually rust and clog the radiator. Next year or so, you can have the dealer do a complete flush and fill if you're really ****. Don't forget to bleed the system. FIlling it back up is a lil bit of a PITA!
Originally Posted by Klumzyee
for 98% of us... its cosmetic
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
lavtxa
Sep 21, 2015 11:51 AM
