Install Borla Dual, UR Crank Pulley, Greenstuff
OK, I just made some SWEET purchases. The Borla Dual Exhaust, Unorthodox Crank Pulley only, Greenstuff Brake Pads. How many hours should I be charged for the install of all three?
Current Mods:
Stillen Hi Flow, Z intake, and Insaname Grounding Kit.
Luv My G
Current Mods:
Luv My G
Re: Install Borla Dual, UR Crank Pulley, Greenstuff
I would install all the stuff yourself..... not too hard to do with a lil know-how. But if you were going for a professional install I would say 1.5 hours for exhaust, 1.5-2 hrs. for the pulleys, and like 30 minutes for the brake pads. These times would be the tops I would pay for installation. Now that should roughly equate to $240 or so for install ($60/hr. x 4 hours). The Borla exhaust is pretty easy to install and no welding is REQUIRED (but it might be necessary if your installer hears some leaks). I am not too sure about the pulley installation as it looks a bit tight to work in there but I'm sure my estimate is more than enough time for a professional to do it in. Hope this helps....
