350Z to G35 coupe Fujitsubo exhaust
Old Nov 13, 2005 | 04:06 PM
safari's Avatar
From a 350Z do i need an extention pipe in order for it to fit properly to a g35 coupe; and where will this pipe go? where can i buy it?
It's for a fujitsubo exhaust and midpipe...
thanks!!
Old Nov 13, 2005 | 04:15 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
Yes, you need an extension (yes, I'm talking about the exhaust )
However, I cannot point you in the right direction on where to get it.
I'd be surprised if Fujitsubo didn't offer one.
Old Nov 13, 2005 | 04:18 PM
al503's Avatar
Fujitsubo probably doesn't have one because they a model for each car. You can pick one up a performancenissan.com for about $50.
Also, the tips on the Z exhaust will be too short to come past the rear bumper. They'll look short.
Old Nov 16, 2005 | 12:44 PM
SI_G35Coupe's Avatar
Performance Nissan has a 6 inch extension pipe available for the Nismo exhaust. since Nismo and Fujitsubo exhaust are the same, this should fit the fujitsubo just fine. as Al said, the tips wont line up exactly right with the rear bumper... although it might not look too bad as the Fujitsubo tips are MASSIVE (i love them though)
http://performancenissanparts.com/ca...roducts_id=340
Old Nov 16, 2005 | 10:07 PM
Frostydc4's Avatar
Is the extension universal (it can be used with any aftermarket exhaust)? If so i'll sell my current exhaust and use the extension with the veilside Ti exhaust.
Old Nov 17, 2005 | 11:48 AM
since the extension pipe that Performance Nissan sells is for the Nismo/Fujitsubo exhaust, it is a 3" diameter (76mm) pipe. i would guess it would work with any exhaust of the same diameter
however... as myself an Al have noted... the exhaust tips in the rear WILL NOT LINE UP with the rear bumper... your exhaust tips will be hidden under your valence by about 2-3 inches. (not to mention all the black crud that will form and possibly heat damage due to the hot exhaust gases hitting the bumper)
Old Nov 17, 2005 | 12:13 PM
waijai's Avatar
i.love.gold
I have a used exension pipe available, and it's actually 8" and not 6". It will work with any Y-pipe back exhaust system.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
