car shut down????
Old Nov 20, 2005 | 03:55 PM
lampin'G35's Avatar
Arrow car shut down????
I just had my crank, sway bars and a intake installed on my 05,G35. So naturally I wanted to test out the difference with everything installed...so I was running my car kinda hard for a couple of gears and I had the C.E.L, the battery light, oil light and the emer. brake light all come on. The power steering went out as well, so I turned the car off at the next light and waited like a minute to turn it back on and when I did it appeared fine. Keep in mind this happened last night and since then I havent had any problems.
I havent the slightest clue as to why this happened ....but any insight would be great
Old Nov 20, 2005 | 07:55 PM
anish3232's Avatar
Try resetting the ECU if you didnt after you installed everything.
Old Nov 20, 2005 | 08:38 PM
Vic's Avatar
Vic
what kind of intake do you have? is it cold air intake? Some people have that kind of problem with cold air intakes.
Old Nov 21, 2005 | 02:29 AM
lampin'G35's Avatar
ya it is an AEM intake, cold air, what exactly do you mean when problems have been associated with these types of intakes?
Ill try and reset the ECU and see how that works
Old Nov 21, 2005 | 03:35 PM
GT-Ron's Avatar
It's the AEM, and a reflash isn't going to resolve the issue. The problem with some of the Cold-Air Intakes have been idle-qaulity issues and, more importantly, a run-down condition where the revs drop too low and stall the car. The run-down issue will show itself when slowing to a stop or otherwise dropping the RPM to a near-idle point. Search and you should find a wealth of info on this... ...if you need any more info. on it. The Injen seems to be the CAI of choice as it gives a decent power increase and, most importantly, doesn't exhibit the run-down/stall and idle-qaulity issues.
Old Nov 22, 2005 | 03:06 PM
lampin'G35's Avatar
I also heard that the cold air intakes aren't good for the G-35, that the z-tube and pop charger are the best and only way to go for positive power gains
Is this true?
Old Nov 22, 2005 | 03:41 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Is this true?
I've had them both and currently running the Injen CAI and love the way the car responds.
Both are nice, but I'll stick wit the Injen
chinee
Jun 10, 2024 07:48 PM
hdmark
Apr 29, 2019 04:31 PM
Joshua615
Aug 31, 2015 12:29 AM
apintojr
Jul 23, 2015 10:52 AM
brian_z
Jul 22, 2015 09:19 PM
