Any suggestions for more N/A power?
[QUOTE=DRG35R]
www.actperformance.com - You'll likely have to call though..
Originally Posted by ISMSOLUTIONS
3.91 EVO gears, TQ Converter, and valve body in the trans...you'll see great 1/4 times...
Can you recommend a TQ converter?
Originally Posted by QuadCam
ISMsolutions,
Who did your headwork? are you using stock heads or the NISMO heads? IF NISMO heads, are they a different casting than the stock heads?
Thanks,
Andrew
Thanks,
Andrew
Did the work myself on the port and polish...been doing them as a hobby from an old profession for 20 years on most every car I've owned...and a few hundred others as well....
G35 Coupe "Sport Package"
www.actperformance.com - You'll likely have to call though..[/QUOTE]
Thanks. I am worried about doing the valve body as I would have to ship cross country and back. Did you notice a huge difference with this mod?
Guest
Posts: n/a
Originally Posted by DRG35R
Thank you for all of the ideas. I think the throttle body sounds good as I have the cams and Doug @ Crawford said to expect another 4-5 HP. I plan on doing the gears in the future along with LSD. The electric fan sounds like a good mod. Does anyone have a system to recommend?
I have 03 5AT and am getting ready to convert to e-fan. DaveO on this board has looked extensively into this mod - it seems there are no off-the-shelf systems that would give you a good system, but DaveO has figured out a nice way to make it work with (single or dual) Flexalite fans, a relay box and hooking in to the existing wiring. I have chatted to him about what is involved - He was very helpful. $200-300 for parts and a bit of work should do it. My car is in the shop, so I will try this after XMas. Search on Dave's posts and drop him a line - he writes for SportZ mag, so maybe he'll churn out an article on this one?
flex a lite would be a good mod as im sure it would give a few hp there located about 5 miles down the road and had on my 05 hemi durango and picked up 16hp and 19tq @ the wheels with awd so im sure for a few hundered it would give u a lil more power. Also u might want to look into a aluminum or carbon fiber driveshaft that will help reduce rotating mass. Another one would be a apexi afc to tune your air/fuel if you dont get a chip. best of luck!!!
I had the valve body done locally - secret - look into TransGo transmission kits - call them and see what you get...hmmm may be just what Stillen didn't want you to know?????
take a look into SGP valve body upgrade, as tested by gurgen:
https://g35driver.com/forums/drivetrain/63397-sgp-5at-valve-body-video.html
i have stillen valve body myself, and i can attest that having it on an NA car is a waste of money.
DRG35R
Sep 16, 2015 05:33 AM
Machine Head
Sep 4, 2015 07:22 PM
