Throttle Response ?
Throttle Response ?
I was drifting down PCH near Big Sur the other day and found it was a bit difficult to throttle correct the tail end in the G35C. There is always that little bit of throttle lag when I punch it, and alittle lag when I release the throttle. That makes drifting so much more difficult since timing is everything.
I was wondering what would be the best cure to improve throttle response on the VQ engine. I think the Drive-By-Wire mechanism really screws with the linearity of the throttle response. (When I stomp on the throttle, it feels like power comes on immediately, but not full power. Maybe a second later then I get full power from the engine.)
btw: j/k with the PCH part.
Hmm, perhaps your experiencing the fact that VDC cannot totally be turned off and it's doing it's nanny thing in holding back the throttle. I actually really like the throttle.
At what speed were you going when you tried to throttle steer?
30-40mph, nothing major. I can feel the power kicking in, but full power doesn't come until alittle later. It's as if the Drive-By-Wire system is asking "Do you really want full throttle? You sure? ok, here it goes"
I agree, everyone's guesses are definately possible contributing factors, but I believe the Drive by Wire throttle still doesn't have the feel and response I have grown use to with all my previous cars, a common complaint from drivers with DBW equipped cars.
I know the reflash changes some of the DBW throttle positions but I don't think it helps with response. It might just be one of the cons of our DBW system. Maybe someone with a reflash can chime in?
Unfortunately, I find the DBW throttle and rediculous stock clutch feel compound each other to really reduce some of the driving experience. I know DBW is technological progress, but somethings are just better left alone.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
