Cam shafts?
Old Jan 7, 2006 | 03:30 PM
IlirG's Avatar
Cam shafts?
Anyone here have any experience with camshafts for the G? They are all pretty pricey, I was just wondering if its worth it. Also I'll be going FI within the next 3-4 months. Thanks
Old Jan 8, 2006 | 01:55 PM
IlirG's Avatar
Anybody? I know most of them cause problems whith your idle. But the JWT seem to "advertise" that there is no idle problems with theirs.
Old Jan 8, 2006 | 04:45 PM
booger's Avatar
I have the Nismo cams and valve springs on my Vorteched G35 . I couldnt tell you about them for N/A set up . As I had them put on after the SC .The vacuum will drop and you'll have a idle problem . There are several fixes [ not really fixes ] You can raise the idle , drill a 1/16 hole in the throttle plate , And T off the vacuum line on the TB and run it to crank case breather hose .I would sugest getting te strongest valve springs you can get . You will be able to rev higher
Old Jan 8, 2006 | 05:52 PM
IlirG's Avatar
Thanks, I am also going with the Vortech. What other mods do you have that compliment your SC? See Im trying to get everything I need (and want ) before May. So far besides my intake, exhaust, plenum spacer, headers, the only other thing I can think of are cams (not to crazy about going with test pipes). Then once I get the SC installed, I'll get a VB upgrade. Anything I'm missing?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
sullivan72
Sep 22, 2015 11:39 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
