Used plenum...What parts do I make sure the seller provides?
Old Jan 12, 2006 | 05:17 PM
Sundeviljay's Avatar
I am buying a used crawfordz plenum. What must I make sure comes with it other than the plenum itself?
Old Jan 12, 2006 | 06:16 PM
99atlantic's Avatar
just say NO to used engine parts.
Old Jan 12, 2006 | 06:47 PM
why?
Old Jan 12, 2006 | 07:01 PM
glennp_1999's Avatar
Are your gaskets still ok? You might want to get a new when you change to the new plenum.
Old Jan 12, 2006 | 07:04 PM
I have less than 25,000 miles, shouldn't my gaskets be ok?
Old Jan 12, 2006 | 07:23 PM
godmans's Avatar
i would say plenum is okay, but it all depends on the price that you are getting. If it is more than $200, I would say why not go with the MD spacer?
Old Jan 12, 2006 | 07:28 PM
I like the look of the crawfordz plenum in black. I can get it for $250. please give me any input because I don't want to buy it you anyone thinks it will be a bad idea. I originally thought it would be a good idea.
Old Jan 12, 2006 | 09:15 PM
techi13's Avatar
1- upper plenum
1-long bolt 80mm
1-long bolt 70mm
2-Nylon washers for use with the two long bolts above
4-short bolts
2-wire loom clamps
2-small nuts (for use with the two wire loom clamps)
heres a link for the install manual
http://crawfordz.com/support/PlenumInstallation.pdf
Old Jan 12, 2006 | 09:33 PM
mgl's Avatar
mgl
you might wanna double up the gaskets.
Old Jan 12, 2006 | 11:55 PM
thanks techi that is perfect
Old Jan 13, 2006 | 12:48 AM
godmans's Avatar
it is that much extra cost...+ 250, why don't you just buy a MD spacer?
or AAM spacer? ..
just my 2 cents
Old Jan 13, 2006 | 07:48 PM
4-short bolts
2-wire loom clamps
^^^are these important? the seller says that he doesn't have these???
Old Jan 13, 2006 | 10:20 PM
bump
Old Jan 13, 2006 | 10:52 PM
techi13's Avatar
the loom clamps and the two nuts for the loom clamps, you can do without, but the 4 short bolts IMO are necessary for proper install (they are used inside the plenum, not sure how easy it will be to find new ones)
check the install guide and you'll see what you need em for
Old Jan 13, 2006 | 11:39 PM
99atlantic's Avatar
Well, you already know my standpoint
I'll never buy used parts - when I had my old mustang, my friends would also try to save a few hundred $$$ buy buying used pulleys and gears....95% of the time their ideas blew up in their face a few months later. I've seen just how 'good' used parts are, but that's just me.
D1dphresh
Aug 7, 2015 06:10 PM
joedaddy1
Jul 28, 2015 02:58 PM
