Motordyne plenum Spacer Problems
Old Feb 18, 2006 | 08:36 PM
MechEE's Avatar
Originally Posted by booger
You seem to know every thing MechEE . You ask a question ????????
And also....a post that is more than one liine....and not negitive ????
WOW !!!!!!!!!!
Hater please.
+3.
Old Feb 18, 2006 | 08:42 PM
MechEE's Avatar
Originally Posted by Hydrazine
Yes, I have dynod the spacer by itself on a REVUP engine and it did absolutely nothing.
As shown on the Motordyne website dyno section, the spacer produces power almost exponentially, on a 287 HP engine, with increasing RPM (up to redline). They can easily produce 10+ HP at redline.
When a "REVUP" lower colletor (with shorter runners) is put onto a 287 HP engine, it can produce a blip of 10HP but it only produces more power in the last ~500 RPM. The REVUP lower collector loses a lot of power everywhere else on the power curve.
So the question is why would Nissan use shorter runners to gain 10HP when they could have made the top half of the plenum a little taller to gain 10+HP and not lose all the TQ and area under the curve? I don't know....
But by knowing how they traded HP for TQ it wasn't hard to figure out a better way to get both.
By switching in a 287 collector (with longer runners) on a REVUP engine, a lot of TQ and area under the curve is made. But there is a very significant rolloff of HP above 6000 RPM.
Now if a plenum spacer is also used on a 287 collector, it will add power very rapidly above ~5500 RPM. So in short, the combination of the 287 colletor with a plenum spacer produces much more TQ and average power under the curve with only a small loss (~3-5HP) above 6200 RPM. Its a very good trade.
Then there is the MREV+. I found through a lot of dyno testing that while larger spacers add more peak HP, they have diminishing returns and even start to lose area under the curve.
It is best to minimize plenum internal volume to maximize TQ but it is best to increase spacer hiegth to maximize flow area above runners 1&2 fo more HP. It is the added heigth that increases flow area to runners 1&2 for HP, but the added volume also diminishes average TQ to all the cylinders.
But why accept a compromise of one or the other? By machining down the excess material above runners 1&2 and then recontouring the inlets, it gives you the best of both HP and TQ.
Minimized plenum internal volume for more TQ and maximized flow area above runners 1&2.
That is what produces the results of the MREV+.
Excellent info. I too find it odd that Nissan would do this.
So with a modified '03-'04 lower collector (MREV+), is there still a need for a 5/16" spacer? It seems there would not be from your explanation, but on your website the MREV+ is an additional option to the MREV packages, which include a spacer.
Old Feb 18, 2006 | 09:36 PM
Hydrazine's Avatar
Yes, it is best to keep the spacer on. A MREV+ without the spacer would have a hair more TQ but have less HP than the spacer.
When I did the dyno testing I found the 5/16" spacer made only a little difference on TQ whereas the 1/2" spacer reduced it quite a bit. Basically, the 5/16" spacer produced the best overall results. The +with a 5/16" spacer gave the HP gains of the 1/2" spacer with the TQ of the 5/16".
Getting the MREV+ and deleting the 5/16" spacer could save some money but I don't think it would be worth it.
Old Feb 18, 2006 | 09:50 PM
MechEE's Avatar
Y
It would also be even stealthier as far as the dealer is concerned.
Old Feb 18, 2006 | 10:39 PM
Hydrazine's Avatar
As stealthy as it gets and still probably the most effetive mod available.
Old Feb 18, 2006 | 11:08 PM
e420x's Avatar
Mod Junky!
Is the Mrev plenum smaller then the stock 2006 stock plenum?
Old Feb 18, 2006 | 11:31 PM
Hydrazine's Avatar
No. Its the same size, just designed differently.
Old Jul 19, 2006 | 03:27 PM
ma_sha1's Avatar
maybe the MD Spacer & Stillen CAT back not compatible?
I had the Stillen Cat back, great, added the 1/2 spacer, got slower,
slowed by 0.2" on 1/4 mile run.
Any one else have both to share experiences?
thanks
Originally Posted by myGspot
i installed my 5/16 a few weeks back. Ran into problems duruing the install when one of the plastic spacers didnt fit on the plenum. I ended up shaving it and modding it enough to fit.
Install is not hard if you know what you doing. But due to the part that wast fitting right it took me about 4hrs to get it done.
My impressions are not great. Before the plenum spacer i had z-tube, test pipes, exhaust. At 3.5k i would feel that it pulled like no other. now with the spacer... the 3.5k pull is not there. It pulled but didnt feel any major difference. At around 6k it looks to be that it revs faster, but then again it could be just me.
May be with my mods before i cant tell teh difference, but i cant say i noticed anything major.
Old Jul 20, 2006 | 12:21 AM
cochinogato's Avatar
only problem i have(still do) - i order the copper ISO- messed with the throttle body and pretty much have had a CEL for the past month- did all the resetting/pedal postioning and still got the CEL time after time after time- so i'll be going up to the dealer to see what they can do :-/
Old Jul 20, 2006 | 12:37 AM
scorcher76's Avatar
5/16" Spacer
Just installed the MD 5/16" spacer today. As far as problems are concerned, after the install, the plenum on the driver's side was hissing / whistling like crazy. After retightening the bolts, hissing sound were gone. Another problem I encounted was the removal of the guide pins. Problems solved by carefully reading Motordyne's instructions
Last but not least, (and maybe some of you can help me), after the spacer installation, I had trouble reconning my Z-TUBE on the plenum. Do I need special spacers for that?
Alex
Old Jul 20, 2006 | 12:39 AM
richie's Avatar
Alex
z-tube should go right onto the throttle body like it did before
Old Jul 20, 2006 | 12:45 AM
speedgeek's Avatar
Poor choice of words for the thread title, but anyway….
Mrev is a great mod, I’m 3k miles into mine and it still gives me a huge grin, and the engine sound is a plus!
your answers...
-does it really make a noticable difference in normal spirited 3-5,000 rpm driving YES
-does it really give you more power? (not like a Z-tube ) YES
-how easy was it to install? 1 to 5 I give it a 3
-any trouble stories of problems after install? NO
-any tips on making the install easier (or saving myself any extra work? Buy a torque wrench
Old Jul 20, 2006 | 12:59 AM
mistermojorizin's Avatar
holy night of the living dead threads batman
Old Jul 22, 2006 | 11:51 AM
Down_Shift's Avatar
Anyone have diy on installing a 5/16 spacer?
Old Oct 14, 2006 | 06:30 PM
  #30
jdmstyleg35's Avatar
is it ok to install just a 5/16" spacer on a REV-UP 06mt?
