engine air filter
Old Feb 8, 2006 | 07:53 PM
dvong's Avatar
engine air filter
Hello g35 folks. Anyone with instructions to change engine air filter? Removing 4 latches do not work. Any pics instruction would be helpful? Thanks
Old Feb 8, 2006 | 08:01 PM
Jeff92se's Avatar
Red Card Crew
1) 10mm wrench to remove the bolt holding down the airbox
2) 10mm wrench to loosen hose clamp holding the rear maf tube to the mid pipe
3) Unclip the maf sensor connector (You might even be able to leave this on)
Carefully lift the maf/airbox assembly away. Replace air filter. Assembly is the reverse of the above.
Old Feb 8, 2006 | 09:57 PM
D87's Avatar
D87
Follow the directions. Pretty simple. Good luck!
http://www.g-owners.com/article_read.asp?id=41
Old Feb 11, 2006 | 05:19 PM
fbpem1's Avatar
1. undo the two clips on the piece coming from the tube (easiest way is with a pocket screwdriver)
2. undo the 10mm bolt holding the box down
3. undo the 4 clips
4. yank up on the box pull filter out, install new filter
5. assemble in reverse order
i do this 2-3 times each day takes no more than 2 minutes =)
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
