The whole ECU reset thing . . .
Old Sep 13, 2003 | 01:56 PM
GeoBau's Avatar
Cactus Hugging Admin
Re: The whole ECU reset thing . . .
We need to arrange a blind test... drive it like a granny for a few days. Have someone you trust implicitly do the disconnect one nigth while you're sleeping, but not tell you on which night. Make sure you reset your A/B odo each night and have them reset radio stations, that way there will be no difference in the interior. Note the shift-patterns, intake sound, etc. and write it down each day... see if your observations changed on the actual day of the disconnect [img]/w3timages/icons/wink.gif[/img] Like I'd trust someone to do a disconnect on my car... either that, or use a Dyno!
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
Old Sep 13, 2003 | 08:09 PM
Shader7's Avatar
OK, I did about 100mi today. Some freeway, a lot of city, and about 30 miles of canyon runs, all after a 13hr neg terminal disconnect. I can still chirp the rears power shifting to third if I get a good run, but no more often than before the reset. The car pulls strong in all the same places, but doesn't seem any more powerful or torquey than before.
My conclusion is that if my ECU had detuned my car in the last 1800 miles, resetting it via the 12hr method did not provide any ostensible benefit. I observed no difference at all.
Perhaps I didn't reset it properly, perhaps my car hasn't "detuned" yet, and/or perhaps the change was too small to measure without objective tools or at least a very accurate butt-dyno. This is only one more (subjective) data point, but I remain skeptical. We really need a well-designed, emprical, data-driven study to find the truth about the ECU reset.
In a couple oil changes I'll try again to see if I notice a difference.
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Old Sep 14, 2003 | 11:43 AM
jcv's Avatar
jcv
ECU adaptation depends a lot on how you have been driving. If you've been grannying it, then the reset may be more obvious. All it takes to re-adapt is a couple of hard runs not weeks or days.
By the way, these kinds of ECU date back to Buick GN in 1986 that used first Bosch Motronic and coil fired plugs in the US. After disconnecting the battery, it usually took a few hard runs for the car to retune itself.
Old Sep 14, 2003 | 02:03 PM
GeoBau's Avatar
Shader- IMO, the reset is much more noticiable in the 5AT, which also makes more sense. I drove a before-and-after of my buddy's 6MT and didn't notice too much of a difference, but that really depends on the driver... the 5AT, however, has a big kick. If you know someone with one, check it out.
G
Freeman186
Sep 6, 2023 10:07 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Joe Gargano
Sep 18, 2015 11:17 AM
Danielek
Sep 10, 2015 06:18 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
