Fuel level sensors which does what?
http://www.g35frenzy.com/forum/showthread.php?t=1044
well if you go to this link... then "fuel systems" it states that one is a main fuel sending unit and the other is a "sub" fuel sending unit.. im still trying to firgure out which does which
That's the manual, I have that but it doesn't say what each unit does.
Terry
The primary sending unit is on the passenger side of the fuel tank hump. The secondary is on the driver side. The fuel pump assembly draws fuel from the resovoir on the passenger side and as it does so, creates a siphon effect which draws fuel from the drivers side to the passenger side for the fuel pump pick up that goes to the motor. The ecu averages the levels of the 2 sensor inputs for the fuel gauge reading. Hope that helps.
master111
Sep 25, 2015 08:32 PM
imma grab my text book and look at what possiblities there are for it
