FS: Innovate SCG-1 Solenoid Boost Controller, AFR, Boost Gauge, Shift Light
Old May 4, 2022 | 08:29 PM
g35life's Avatar
Parting out my car. 3 in 1 gauge.
- Boost Controller - Boost Gauge - AFR Wideband Gauge
Also has shift light and even boost cut if AFR is not within chosen parameters.
Loved this gauged with my turbo setup.
makowskib@gmail.com Contact.
$300 USD
All-in-one, intelligent boost controller and wideband air/fuel ratio controller - Controller and display housed in 52mm (2 1/6”) gauge body - Patented DirectDigital™ Wideband Technology - Boost control adjustment up to 44psi (4 BAR MAP Sensor) - User programmable boost cut safety using Air/Fuel and Pressure references - Programmable waste gate reference pressure threshold - Programmable solenoid duty cycle with separate gain control function - No PC required for configuration and use (Required for data logging) - OLED user configurable display - Programmable shift light - Wideband O2 Compatible with ALL fuel types - Ability to calibrate O2 sensor for maximum accuracy - One configurable linear 0-5v analog output - 4 channels of log-able data (MAP, RPM, A/F, WG duty)
Old May 4, 2022 | 10:58 PM
Urbanengineer's Avatar
Nice piece GLWS.
Old May 23, 2022 | 09:01 PM
g35life's Avatar
thanks urbanengineer!
SOLD.
WINTERDEVILG35
Interior
Jul 31, 2009 05:12 PM
atldpg3503
Archived Sales
Apr 24, 2008 06:48 PM
MyLilBlkG
Forced Induction
May 1, 2005 03:16 PM
