WTB: 2003/04 G35 Sedan OEM Y-Pipe and Mid-Pipe
Old May 13, 2012 | 12:00 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Originally Posted by g35man04
first off OP any 03-07 Coupe or Sedan y pipe will fit. the listed pink you have is the HR Y pipe which came on the newer g37's...07 Sedans that are g35's may be an exception with the HR Y pipe but they all bolt up across the board. The picture that was listed is not what you get actually...
With that being said I have an 04 Sedan mid pipe sitting in my shed if you need one. Would need to pay alittle bit for it because shipping will be around 100.00 dollars roughly.
here is an 03-07 coupe and 03-06 sedan y pipe versus HR y pipe
Wrong, the 2WD Y is pictured on the left, the AWD Y is like the one pictured on the right in order to clear the transfer case. The HR-Y is also like the one on the right, which is why it is said that there is no need for a g35x to switch to an HR-Y since they are similar. OP I have an '06 midpipe for sale, it will bolt right up no problem.
Old May 14, 2012 | 08:25 PM
kswan53's Avatar
Thanks. I PM'd you.
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
