JWT Pop-Charger & Motordyne 5/16" Basic Spacer
Old Oct 17, 2011 | 07:12 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Condition: USED
Price: $1
JWT Pop-Charger - $75
- cleaned regularly, everything is in good shape. Includes brackets and heatshield with C.A.R.B. Sticker.
Motordyne 5/16" Basic Spacer - $180 Installed (Will need your stock bolts in return)
Old Oct 17, 2011 | 09:23 PM
Cambria's Avatar
$60 for the popcharger? Where in SD are you located?
Old Oct 17, 2011 | 11:05 PM
$70 and it's yours, i'll even install it for you. Scripps Ranch.
Old Oct 17, 2011 | 11:08 PM
CandlestickPark's Avatar
ill Sedan
BUMP for the homie. Nice parts I used to run both of these myself. GLWS Grant.
Old Oct 19, 2011 | 05:06 PM
Calvin's Avatar
Overglorified Altima
bump
Old Oct 20, 2011 | 02:34 AM
funnyscreenname's Avatar
what's the difference in that spacer and the other spacer packages? is it just that the other packages come with the lower gasket and tb gasket as well?
Old Oct 20, 2011 | 10:52 AM
The basic spacer only comes with the spacer and hardware.
The ISO-Thermal comes with the CCV and an aramid gasket to go between the motor and lower plenum.
The copper iso thermal comes with everything above plus a copper gasket that allows coolant to run through it to keep the throttle body from freezing in areas where temps are regularly below 50*
Old Oct 20, 2011 | 10:58 AM
herrschaft's Avatar
So, you don't have the ISO thermal kit?
Old Oct 21, 2011 | 01:12 AM
Nope, this is just the basic spacer with hardware. Sells for $230 new from Motordyne and doesn't take any wear and tear being aluminum so it's a damn good deal.
Old Oct 23, 2011 | 12:26 PM
Bump!
Old Oct 25, 2011 | 11:14 AM
Ionic's Avatar
PM sent.
Thanks!
Old Oct 28, 2011 | 03:13 AM
G35AndTGOD's Avatar
70 Shipped to 92505? not wanting to drive to san diego -__-
Old Oct 28, 2011 | 05:27 PM
Calvin's Avatar
^^^not wanting to sell for $70 shipped -___-
bigmike
Sep 17, 2015 01:58 PM
SIKKI
Steering & Suspension
Sep 16, 2015 01:14 AM
Albanian122
Sep 12, 2015 04:02 PM
Terry_G35
Sep 10, 2015 08:17 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
