FS: Motordyne MREV2 & 5/16 spacer
Old Dec 1, 2011 | 08:57 PM
BLACK-G35TT's Avatar
Motordyne Mrev2 manifold and 5/16 spacer for sale. $450 for both
MREV 2 Manifold TM - The most powerful naturally aspirated bolt on you can put on your revup engine.
When used with or without a spacer or aftermarket upper plenum, this lower plenum will make substantial power gains. Multiple independent test show when used with a 5/16" spacer on the revup engine, the combination will add a "minimum" of 15+ HP and 18+ TQ in the upper midrange. Many independent MREV 2 Manifold REVUP tests have dynod in excess of 20HP and 30 TQ in the upper midrange and with high RPM peak power increased by 3-5 HP.
The MREV2 is a prerequisite to the plenum spacer when used on a revup engine. No other normally aspirated VQ modification provides as much gain as the MREV 2 Manifold!
Old Dec 3, 2011 | 02:16 PM
jimmyboi860's Avatar
can you check if its an authentic MREV2 please? if it is im interested in both
Old Dec 3, 2011 | 02:29 PM
alfhasg35's Avatar
https://g35driver.com/forums/engine-...ification.html
Old Dec 3, 2011 | 05:41 PM
carsfreak88's Avatar
what he have for sale is a regular non rev up lower plenum
Old Jan 3, 2012 | 12:25 PM
Hydrazine's Avatar
Neither is a Motordyne spacer or Motordyne MREV2.
Old Jan 3, 2012 | 12:30 PM
Shanes_G's Avatar
ill give you 150 for for both.
Old Jan 3, 2012 | 05:39 PM
devin7632's Avatar
How much for just the spacer. i am located in Sacramento so we can do a meet up
Old Jan 4, 2012 | 08:40 AM
bricks's Avatar
Are you saying that the motordyne spacer and motordyne mrev2 are borh FAKE?
Old Jan 4, 2012 | 08:47 AM
Frankieg35's Avatar
Yes that what he is saying..
Old Jan 4, 2012 | 05:21 PM
Hydrazine's Avatar
Yes.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
