FS: Power Enterprise Twin Turbo Kit $2000
Hey Algy,
I am not sure, I googled to see if I could up with some info and no luck. I also checked the installation manual and found no mention of "automatic" or "5at".
^that really depends on how elaborate of a setup you want. I would highly suggest you research forced induction before making a purchase like this. At the very least you will need fuel pump, injectors, oil pan spacer, etc..
Free easter bump. I think I'll have to pass on this kit. I'll be using the money I get to buy a UAS set up. If I do the TT setup it'll be after I fully build my motor.
