Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Cosworth CNC Ported Big Valve VQ35 Cylinder Heads on Sale!
Old Jun 15, 2006 | 03:48 PM
partshipperdave's Avatar
Exclamation Cosworth CNC Ported Big Valve VQ35 Cylinder Heads on Sale!
We at PartShippers.com are excited to be able to offer the g35driver community this exceptional offer on these amazing performance cylinder heads from Cosworth!
We have them on sale for only $3999.00!
Cosworth CNC ported cylinder heads feature dyno tested and flow bench proven ports, engineered for maximum usable power. Each new cylinder head is ported on a 5 axis machine to ensure consistency and perfect port shape every time. Additionally, larger intake (+1mm) and exhaust valves (+1mm) are utilized to help increase flow. Cosworth CNC ported Big Valve cylinder heads come complete with a performance valve job, hi rev (max 10,500rpm) valve springs with titanium retainers and are ready to install. Perfect for high performance applications and designed for excellent torque and turbo response.
• CNC Ported/Machine finished port- New Castings
• Hand blended finish work
• Intake –19% (max) increased flow
• Exhaust – 22% (max) increased flow
• 4-angle Inlet Valve job
• 3-angle & radius Exhaust Valve job
• Valves are lapped
• Back-Cut Inlet Valves
• Heads are Ultra Sonic cleaned prior to assembly
• Heads are Serialized and sport a machined Cosworth logo
• +1mm Stainless Steel Intake Valves (1800 degrees max.)
• +1mm Inconel Exhaust Valves (2400 degrees max.)
• Performance Valve Springs
• Titanium Retainers
• Hardened Steel Spring Platforms
• Knife edged port divider
• Combustion chamber volume 58.5cc’s (OE approx 56 cc’s)
Link to item in our online catalog:
http://www.partshippers.com/index.ph...roducts_id=992
In stock and ready to ship!
Thanks all for your support and interest.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
lemmy999
Jul 25, 2015 12:13 PM
