Stillen Oil Cooler W/ Mobil 1 Full Synthetic Combo
For sale is the stillen oil cooler kit with 5 quarts of Mobil1 full synthetic motor oil. By cooling the engine's oil, the life and quality of the oil are improved while thousands of miles of life are added to high-wear engine components such as piston rings, piston skirts, cam bearings, and rod bearings. This Heavy Duty Oil Cooler Kit comes complete with all of the necessary adapters, fittings, and hoses that you will need for installation. This will require the drilling of mounting holes to install this kit. Instructions are included. THIS KIT WILL FIT THE 350Z AND G35 COUPE, BOTH 6SPD AND AUTO.
THIS KIT WILL FIT 2003-2006.
PLEASE PM ME FOR PRICING AND AVAILABILITY
I just had mine installed by the dealer. Yes i know, lazy. Anyway it runs as an extension of the stock cooler. Dealer mounted mine in front of the radiator almost completely behind the bumper support (the giant beam that saves you in a front end collision). But the nice steel braided lines run right through the grill and also run in the front passenger bumper opening. Maybe its just me but it seems the useless stock temp gauge seems to sit a 100th of an inch lower. Perhaps you can find a more effective place to mount it than the dealer did, but regardless, the car runs cooler. I can tell. Remember the braided lines radiate heat also. The air from the bottom of the car doesn't quite burn my legs hairs off anymore. I did this mod to satisfy my thirst to do something useful and somewhat cheap to the car. I haven't had an oil change yet but i expect the oil to be in better shape when its is time to change it.
i am a new member so i doubt it, if your referring to me. I have this part already just wanted to comment on its effectiveness. Also, talked to the dealer today, they can measure oil capacity to fill. Which is good since the dipstick is useless. They say with the cooler on the car now takes exactly 5.79 quarts. just fyi everyone.
seagrasser
May 3, 2022 09:43 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
