Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
OEM/ Stillen Z Tubes! Great low price!
Old Mar 6, 2007 | 02:38 PM
Mike@CZP's Avatar
Brand new OEM Z-tubes for the G35 and Stillen Z-Tubes
Stillen Z-Tube Infiniti G35 $75.00 SHIPPED
The intake tract on the G35 and FX35 was not designed for maximum performance. Many enthusiasts have changed to the 350Z piping which is more aerodynamically efficient. Our new STILLEN "Z-Tube" is a lower cost and better way of maximizing air flow in your G or FX. This is a rotomolded plastic part that has excellent insulation qualities. This helps to isolate incoming air from engine heat, the colder air produces more power. Use this with the stock airbox or for maximum gains add the JWT or Stillen Intake.
CZP Silicone G35 Z-Tube 03-07 Coupe, 03-06 Sedan $60.00 SHIPPED
Nissan OEM 350Z Intake Hose Upgrade for G35 $168.62 SHIPPED
These 350Z intake hoses replace the original G35 intake hose. Submitting smoother air flow, you will experience a 4-6HP increase. This setup works perfectly with the JWT Pop Charger.
JWT G35 Pop Charger/350Z intake pipe combo $249.00 SHIPPED
To get the most potential of your intake system, the JWT Pop Charger/350Z Intake Combo Package is the way to go. With a combined 12HP increase, these two items pack a punch. Installation is less than 30 minutes, all hardware and instructions are included.
POP-Charger air filters are designed for maximum air flow by using a 6" diameter venturi surrounded by an oiled gauze filter element. The filter element is reusable after cleaning and reapplying filter oil. POP-Charger aluminum venturis are made from lightweight cast aluminum and CNC machined by us to ensure a quality fit. Product comes with Intake, Adapter, Heat Shield, and Bracket. HP Gains are around 6-7 RWHP, and you'll notice a nice new agressive sound from the engine.
The 350Z Intake pipe is larger in diameter then the original G35 intake pipe, and allows for more airflow (6HP Gain). The 350Z pipe is a direct replacement.
JWT G35 Pop Charger / Stillen Z-Tube Intake Pipe Combo $170.00 SHIPPED
JWT G35 Pop Charger/Silicone Z-Tube Intake Pipe Combo - V35 $155.00 SHIPPED
If order online, put G35driver.com quote in the comments section!
Old Mar 12, 2007 | 04:55 PM
kay350gt's Avatar
bump for a great starter mod
Old Mar 12, 2007 | 05:51 PM
Mike@CZP's Avatar
thank you!
Old Mar 12, 2007 | 06:32 PM
MRMEATY's Avatar
Is the 350z one worth the extra money over the Stillen? Is the POP Charger woth the extra 130 bucks? I have a drop in K/N already.
Old Mar 12, 2007 | 06:47 PM
Calvin's Avatar
Overglorified Altima
the stillen ztube will work just fine. imo, there is not advantage/disadvantage to either. they're just intake tubes.
p/c will give you a nice growl if that's what you're looking for. other than that, no.
Old Mar 12, 2007 | 08:43 PM
MRMEATY's Avatar
Thanks for answering my questions and not coming back with some smart answer like some people are doing on this forum. If I hear "search" one more time......
Old Mar 12, 2007 | 08:44 PM
Mike@CZP's Avatar
haha no he is right. Only thing I hear about the stillen is sometimes they have fitment issues, but I have not had too many complaints from the customers.
Old Mar 12, 2007 | 08:45 PM
Mike@CZP's Avatar
And yes, the pop will give you that nice sound, plus its JWT. They are very popular and sell like mad, so they must be doing something right! But if you dont want that extra mean sound, then the K & N will work just fine. Thanks for the inquiry
Old Mar 12, 2007 | 08:57 PM
MRMEATY's Avatar
Thanks again.... pulling the DEBT cardout right NOW!
Old Mar 12, 2007 | 09:03 PM
Mike@CZP's Avatar
Old Mar 14, 2007 | 07:43 PM
GfknDIRTY5's Avatar
G"dirty"5
JWT G35 Pop Charger/350Z intake pipe combo $200.00 SHIPPED
Even shipped to 96816/
Old Mar 15, 2007 | 02:13 AM
Mike@CZP's Avatar
Yeah Ill do that price even shipped there. Should be no problem.
Old Mar 15, 2007 | 03:04 PM
Mike@CZP's Avatar
bump
Old Mar 16, 2007 | 02:00 PM
kako's Avatar
how about a stillen Z-tube/Pop Charger combo ?
Old Mar 16, 2007 | 02:20 PM
ttrank's Avatar
Grocery getter
How about a Stillen intake and Stillen tube combo.
Have a friend looking for one right now.
