***Turbonetics Single Turbo Summer Special*** w/FREE AAM SPEC Oil Pan Spacer
AAM Late Summer SPECIAL: Turbonetics Standard Single Turbo Kit plus FREE AAM SPEC Oil Pan Spacer & Oil Return Line Upgrade!!!!
Pricing Details:
Total Single Kit w/Cat: $6,079.75 Installed at AAM
Total Single Kit w/Cat: $4,795.00 Shipped
Total Single Kit wo/Cat: $5879.75 Installed at AAM
Total Single Kit wo/Cat: $4595.00 Shipped
Package Includes:
•Turbonetics Single Turbo Kit (With or without catalytic converter)
Product Details:
•The Turbonetics Single Turbo Kit has a very straightforward, easy installation. Because there is only one turbo, there is nearly ½ the components in this kit!
If you have any questions give us a call at 301.330.8835 or drop us an Email at Sales@AlteredAtmosphere.com
Thanks,
Altered Atmosphere Motorsports
CHAT WITH US LIVE
Pricing Details:
Package Includes:
•Turbonetics T4 60-1 Ball Bearing Turbocharger Capable of supporting 500hp (engine)
•Stainless Steel Turbo Exhaust Piping. Uses the factory exhaust manifolds
•Turbonetics 38mm External Wastegate
•3” Stainless Steel Downpipe (Specify with or without Cat). Replaces the factory Y-Pipe. Connects directly to the stock exhaust system.
•380CC Injectors
•Walbro 255lph In-Tank Fuel Pump
•Turbonetics ECU Flash (when the kit is being installed, the customer and/or shop sends the factory ECU to Turbonetics in the pre-labeled & pre-paid overnight box that comes in the kit. Turbonetics will flash the computer and send back normally with-in two days at no additional cost).
•380CC Injectors Scaling Pre-tuned for a basic/overly rich & conservative 7.5psi setup
•Polished Aluminum Turbo & Intercooler Piping
•Black Silicone Connectors
•AAM Oil Pan Spacer and AAM Oil Return Line Kit •Stainless Steel Turbo Exhaust Piping. Uses the factory exhaust manifolds
•380CC Injectors
Included FREE in every Turbonetics kit sold during this limited offer, is our AAM Spec. Oil Pan Spacer & Stainless Braided Turbo Oil Return Line Upgrade. The AAM Spec. Oil Pan Spacer and Oil Line Kit help guarantee a leak-free installation and better cooling through increased oil capacity. In addition, this upgrade greatly improves long term reliability. The stock kit setup requires you to tap the engine block for the oil return line. The factory block, however, is an aluminum casting and the Turbonetics oil fitting is a bronze fitting. As a result, the difference in the expansion/contraction rates of the aluminum block vs. the bronze fitting can lead to cracked components. With the AAM Spec. Aluminum Oil Pan Spacer and AAM Spec. Aluminum Oil Return Line Upgrade this problem is eliminated because our aluminum AAM Spec. Oil Pan Spacer comes pre-tapped for our upgraded aluminum oil return line fittings.
•Optional Installation at AAMProduct Details:
With spool-up beginning as low as 2,000rpm and full boost between 2,800 and 3,200rpm, this kit provides a ton of low-end torque and power. This turbo kit runs ~8psi out of the box and, on average, makes between 340-360rwhp. With an upgraded fuel system, larger injectors, and tuning management customer commonly make between 370-410rwhp (430 to 480 engine horsepower!). Add a built motor to the mix, and this system has proven itself between 430-450rwhp (510 to 530 engine horsepower!).
Thanks,
CHAT WITH US LIVE
