***EXEDY CLUTCH & Flywheel SPECIALS***
We're pleased to offer you folks some great deals on EXEDY Clutches. Stage 1 and Stage 2 are both in stock ready to go. The Twin Carbon Clutch Kits are a 1 week wait time.
We recommend the Stg 1 for modified N/A cars and going for Stg 2 for FI cars!
STAGE 1 Organic Clutch Kit
EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of our clutch discs have spring center dampers to reduce drivetrain shock.
Specs:
Number of Discs SINGLE
Clamp Load (Lbs) 2269
Disc Outer Diameter 250
Spline Teeth / Major Diameter 24T / 25.6
Price: $475 SHIPPED
STAGE 2 Cerametallic Clutch Kit
EXEDY cerametallic clutches are designed to handle the abuse of high powered modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All cerametallic discs feature spring center dampers to reduce impact and shock loads.
Specs:
Thin / Thick Thick
Price: $750 SHIPPED
Twin Disc Carbon Clutch Kit
EXEDY's claim to fame: the carbon steel multi plate clutches. These clutches are light in weight, durable, and resilient to high heat, contributing to an improvement in track times. These complete bolt on designs require no additional modifications to the vehicle. The carbon materials are baked at more than 2000 degrees celsius which allows the the carbon material to dissipate heat far better than conventional metallic material. This heavy duty set can handle the load from high horsepower turbocharged Z33 and CPV35 applications.
Price: $2450 SHIPPED
Lightweight Racing Flywheel
EXEDY Racing Flywheels are made from solid one piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response.
They incorporate special design features to enhance air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and have the possibility of separating from the flywheel. Less mass keep you on that higher RPM!
Price: $775 SHIPPED
Specs:
Price: $475 SHIPPED
Specs:
Thin / Thick Thick
Price: $750 SHIPPED
Price: $775 SHIPPED
magnetism80
Feb 1, 2019 10:00 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
