***AAM Throttle Body Spacer Sale***
Oct 9, 2007 | 01:46 PM
In-Stock and ready to ship!
Retail 99.99
Sale 79.99!!!
The AAM Spec. Throttle Body Spacer is a great addition to any upgraded 350Z or G35. Each AAM Spec. Throttle Body Spacer comes pre-tapped with three vacuum ports. This saves both time and money when running vacuum lines (no need to tap the factory intake plenum with this spacer). Because you have more vacuum ports available you can run components seperately (ie. map sensor, boost gauge, fuel pressure regulator, boost controller, etc.) which improves both their performance and reliability. This will fit any VQ35DE engine (350Z, G35, Maxima, Altima).
If anyone has any questions, wants shipping quotes, or has general comments, feel free to pm, email, or call me.
Reply 0
so what exactly does this thing do?
Reply 0
Oct 9, 2007 | 04:58 PM
Reply 0
Oct 10, 2007 | 11:13 AM
Are the vacuum ports on the top, side or bottom?
Reply 0
Oct 11, 2007 | 09:18 AM
Quote: so what exactly does this thing do?
It's perfect for FI setups. You can connect a UTEC manifold absolute pressure sensor to the vacuum tap on the TB spacer. Great way to have a clean, reversible install. I've got one, they built my car.
Reply 0
Oct 11, 2007 | 12:13 PM
Quote: Are the vacuum ports on the top, side or bottom?
The vaccuum ports are on the top. And to add to what Aero said, our Throttle Body Spacer comes pre-tapped with three vacuum ports. This saves both time and money when running vacuum lines (no need to tap the factory intake plenum with this spacer). And because you have more vacuum ports available you can run components seperately (ie. map sensor, boost gauge, fuel pressure regulator, boost controller, etc.) which improves both their performance and reliability.
Reply 0
Oct 22, 2007 | 10:06 AM
Bump for Monday
Reply 0
