NGK Iridium Spark Plug Sets - Regular, One Step Colder, and Two Step Colder
-----NGK Sparkplugs-----
Iridium Regular - LFR5AIX-11 (Naturally Aspirated Engines)
$50
Double Platinum - PLFR5A-11 (Naturally Aspirated Engines)
$71 Shipped (within the US)
Platinum - LFR5AGP (Naturally Aspirated Engines)
$44 Shipped (within the US)
V-Power - LFR5A-11 (Naturally Aspirated Engines)
$38 Shipped (within the US)
I have an NA 05 G35 Coupe with 70k and I'm going thru a maintenance overhaul. What tips are best for this vintage in your humble opinion. The car is not going to be modified for uber power. I just want performance and good ultimate MPG with these plugs.
Thanks, will pay up upon answer!
PB
$50
PB
Double platinum is what comes with the VQ from the factory. We like using the iridiums because they last longer, have a more consistent spark, and are also cheaper. But it all comes down to personal preference which is why we offer the different choices.
plug temp has nothing to do with outside temp, as we state in the first post they are for forced induction vehicles, unless you are running a custom tune, then it is upon the tuner to recommend the proper set of plugs for your vehicle.
$50
PB
$50
PB
For the VQ there are some things in the way, would not recommend for everyone. But you if you can do basic bolt ons should be fairly easy, there is a DIY on my350z as well to install them.
