Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Cobb Tuning Accessports In STOCK - G35 FITMENT + Credit
Old May 14, 2008 | 05:05 PM
Iperformancellc's Avatar
FREE OVERNIGHT SHIPPING IS ALWAYS INCLUDED FOR MEMBERS
COBB TUNING -G35 AccessPORT - AP-NIS-002
IN STOCK ALL ORDERS RECEIVE OVERNIGHT SHIPPING
Fits: Infiniti G35 2003-06 ;
**Excluding 2003-early 2004 G35 Sedans**
Details:
The AccessPORT is the most user friendly reprogramming device for your vehicle's computer. The provided mapping will optimize the air/fuel ratio and ignition timing, remove the speed limiter, and more for performance results you can instantly feel!
But the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor your Fuel Economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly and cluttering aftermarket gauges! With the added ability to adjust timing and idle, the AccessPORT is truly more than just a programmer, it is the ultimate all-in-one solution for the G35 enthusiast.
Please be aware that this device is currently not compatible with G35 Sedans with build dates from 2003 through May 2004. See the bottom of this page for further information.
MORE INFO:
These units were designed as a answer to all your tuning needs. These were first developed for the subaru applications and are now out selling turboxs 3 to 1. They are plug in play inside your vehicle, Easy to use, easy to tune on your own, they have live displays like air\fuel, boost, egt temp, etc. They are also the size of an I pod can be mounted anywere or hang free, and come with a color screen for easy to see fuel maps. No laptop required, the list goes on and on.
Visit http://www.cobbtuning.com/products/?id=3687 for more information view the subaru section and the forums for videos and more, this is the same device its just wired to work with the G35and has different base maps and slight software changes to best fit the G35 .
INSTALLATION:
Just about anyone with even the most basic of automotive knowledge can quickly and easily install an AccessPORT. No soldering, wire cutting/splicing or tools required.
AccessPORT Settings:
Customize the AccessPORT by changing settings, such as selecting the language for displaying text.
About AccessPORT:
Displays information about the AccessPORT firmware, serial number, and vendor. Easily check to make your AccessPORT stays up to date with the most current firmware.
Mode Switching:
Change mode of engine management for staged performance, fuel economy, theft deterrent, race mode or custom performance.
Show Current Map:
The AccessPORT can display the last map it applied in real time and the last map that it reflashed. To see the current map, select “Show Map” from the AccessPORT main menu.
Fuel economy gauge:
Monitor average and instantaneous fuel economy estimates to improve your driving techniques for optimal fuel efficiency. Customers have seen over a 5%-10% improvement in fuel consumption when used in conjunction with the Fuel Economy Map.
Display engine parameters:
Check vehicle performance by monitoring engine parameters. The AccessPORT can read sensor data from the factory ECU and display it on screen. This feature allows the AccessPORT to function as an auxiliary gauge to display RPM, Boost, Coolant Temp., Battery Voltage, Intake Air Temp., Ignition Timing, Mass Air Flow and many more.
Rev Warning/Shift Light:
The screen will flash to indicate that a pre-set shift RPM has been exceeded while viewing engine parameters. The pre-set shift point is user settable through the SETTINGS menu.
Performance:
The AccessPORT measures and displays 0-60 mph acceleration,
60 ft. time, 1/8th and 1/4 mile E.T. and Trap Speeds. Use this feature to quantify performance modifications and driving techniques.
ECU Tool & Settings:
Control basic engine functions and convenietly reset the ECU from the comfort of the drivers seat instead of manually disconnecting the battler and losing all your radio presets and having to reset you clock.
Read engine diagnostic codes:
Avoid an expensive trip to the dealership by reading the codes describing an illuminated check engine light. The provided code description may help to determine the cause of a problem.
Nissan G35 AccessPORT features are as follows:
» Improve horsepower, torque, and fuel economy at the touch of a button
» Adjust timing +/- 2 degree's
» Adjust idle +250rpm
» Display vehicle data such as RPM, temperatures and more while you drive
» Easy installation, no mechanical or computer skills necessary
» Connects to your vehicle via the OBD-II port conveniently
» Exclusive ability to switch between different 'modes' on the fly
» Pre-calibrated to maximize performance of stock or modified vehicles
» Easy-to-read color display
» Update over the Internet to stay up-to-date with the latest features
» Read engine trouble codes (DTC) yourself, eliminating trips to the dealership
» Not a "piggyback" - once vehicle's computer has been programmed by the AccessPORT, it can be removed and the settings will stay on your computer.
» Not just an "ECU reflash" - AccessPORT features enhancements such as on-the-fly mode switching, data monitors, reading DTCs, performance monitors and more
» Can be custom tailored to your vehicle by our extensive network of professional tuners
Please Note: This part will only work with North American Infiniti G35.
AccessPORT (Stage 1 Kit) Includes:
- AccessPORT
- Quick Start User Guide
- USB Cable
- OBDII Connector
- Software CD
Old May 14, 2008 | 05:25 PM
SxExCx's Avatar
price please
Old May 14, 2008 | 05:52 PM
empfl's Avatar
Originally Posted by sxexcx
price please
$695 + free shipping.. sooo $695?
Old May 15, 2008 | 05:01 PM
All Sent
Old May 15, 2008 | 08:25 PM
bobshuai's Avatar
pm for pricing.
Old May 15, 2008 | 10:47 PM
Please clean your inbox or email us, there is no room to send you a pm
Old May 17, 2008 | 09:22 AM
risingson's Avatar
damn.. these just came out huh?
i want one bad.. but i gotta wait.
Old May 19, 2008 | 03:03 PM
Sure ..
Old May 19, 2008 | 09:50 PM
G_XXXV's Avatar
Will mine arrive tomorrow?
Thanks.
Old May 22, 2008 | 07:09 PM
Already arrived you missed delivery from fedex though
Old May 25, 2008 | 05:41 PM
05350GT6MT's Avatar
price shipped to 93722
Old May 27, 2008 | 02:12 PM
Dont miss out on our Store credit and rebate offers on all items we sell
Old May 27, 2008 | 04:22 PM
RyanFow's Avatar
can you use the AccessPORT with aftermarket intakes, cat backs, plenum, spacers, ect...? I thought I read something that you couldn't use it with some mods?
thanks!!
Old May 28, 2008 | 12:06 AM
monkeywinky's Avatar
price to 91731, do we get store credit?
Old May 28, 2008 | 03:48 AM
Where did you read that this is a after market ECU its made for all mods, You just need to tune it for any major upgrades you make. Its completely user friendly any body can tune if you follow the simple instructions. This device also does many other things that the UTEC does not, For one it can be used as a live gauge and also it reads Cel light codes and many other things.
