Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Flat shifting is finally HERE!!!With 2 step!!!
Old Jun 14, 2008 | 07:53 PM
Julian's Avatar
Exclusively available at MRC Motorsports we will begin shipping the 350Z WOT boxes shortly! This will allow the user to flat shift the 350Z and save on expensive drivleine components
The unit will cut the power to the ignition coils when the vehicle is Wide Open Throttle and each time the clutch is depressed.
Video of it in action on my car:
Videos of 2 step:
Thanks to Jay@N2MB for hooking this unit up!! It hooks up in a matter of 15 minutes tapping off only 3 wires.
The ignition coil power, the clutch swithc and the TPS switch, thats IT!!
The WOT shifting will cut ignition from 25ms up to 700ms, all set by the end user by simply holding the buttot on the unit down till the blue LED starts flashing, each flash is 25MS incriments...
I am telling you guys, this unit will lower drag racing ET's!!!
What is WOT?
WOT stands for Wide Open Throttle.
What is the WOT Box?
The WOT Box is an electronic device that makes WOT shifting easy by reducing your engine's power for a very short timed period while you shift. It allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. If the input shaft on a manual transmission is not allowed to slow down enough it will lock you out of gear time after time. We have developed a solution to the problem by controlling the ignition at the shift point to ease the transition from one gear to another.
What is WOT Shifting?
WOT shifting is a common practice used by drag racers regardless of if they are running turbo, supercharger or naturally aspirated. WOT shifting is accomplished by holding the gas pedal to the floor and never "lifting" off the gas during the shift. The problem with doing so is when you depress the clutch engine RPMs flare up and a brief amount of time is required for the transmission input shaft to slow down. Even the most successful drivers have been known to miss a gear occasionally. It requires complete concentration and lightning quick reactions in order to pull it off.
"Keep the pedal to the metal, blip the clutch, and grab the next gear. Do it fast enough before the redline, and your reward will be a zero lag, constant boost shift."
How does the WOT Box make WOT Shifting easy?
Our WOT Box momentarily disrupts the engine power long enough for you to make an effortless, fast WOT shift. The result?
  • Lower ETs - One of our big turbo customer cars dropped their E.T. in the quarter mile from 12.0 to 11.3 seconds just by adding the WOT Box!
  • Reduced chance of missing a gear
  • More consistent, effortless shifts
  • Reduced wear on the transmission
  • Reduced chance of major transmission damage
Group buy thread here!!
https://g35driver.com/forums/showthr...00#post3121100
Old Jun 14, 2008 | 10:27 PM
Canadian's Avatar
Canada, eh?
I haven't been keeping up but a) why is this in FI and b) isn't there already a thread regarding this?
Old Jun 15, 2008 | 03:37 AM
Julian's Avatar
A) most traffic and most useful feature for FI guys
B) deleated for off topic banter and postings from other vendors, that were out of line. Since no one was moderating it despite my repeated reported posts,
Old Jun 22, 2008 | 07:42 PM
Julian's Avatar
The 350Z/G35 WOT BOXES have begun shipping!!
Old Jun 23, 2008 | 05:21 PM
civic4982's Avatar
GB link not owrking.
Old Jun 23, 2008 | 09:12 PM
Julian's Avatar
Bah, you need to be Premier Memeber on this site to see the group by..
You can just call or paypal sales@racemrc.com to order.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
Since 1983
Sep 19, 2015 10:26 AM
Jon81035
Sep 16, 2015 04:58 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
