Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Engine Management: Access Port -+ Ft/lb, HP, Fuel Economy Etc.!
Old Oct 15, 2008 | 03:17 PM
Iperformancellc's Avatar
Bump It Up
Old Oct 27, 2008 | 01:42 PM
Bring It Up For Cobb Rebate
Old Nov 10, 2008 | 12:39 PM
Bring It Up !
Old Nov 12, 2008 | 09:16 PM
G37 Port Now Available
Old Nov 25, 2008 | 04:46 PM
Black Friday Sale!
Old Nov 29, 2008 | 11:33 PM
Bump It Up Xmas Sale?
Old Dec 3, 2008 | 03:48 PM
New Base Maps Released From Cobb
Old Dec 4, 2008 | 06:10 PM
Xmas Sale!
Old Dec 6, 2008 | 06:30 PM
Major Sale
Old Dec 6, 2008 | 06:54 PM
Texasscout's Avatar
So, acording to your specs, a 2005 "rev-up" will gain 11.5 hp with this mod. OK, what's it cost? PM me.
Old Dec 6, 2008 | 07:02 PM
You will gain alot more then that !!!
Old Dec 6, 2008 | 07:20 PM
Texasscout's Avatar
Just going off your POSTED specs:
2005 Infiniti G35 Sedan Manual
Stage1 (+3.8% HP/+1.5% lb-ft.) & Stage2 (+7.2% HP/+6.8% lb-ft.) performance calibrations. Minimum of 91 octane fuel.
Stage2+ is intended for vehicles with cat-back exhaust, headers, plenum spacers, high flow catalysts or race pipes, and aftermarket intakes.
306hp x 0.038 (3.8%) = 11.628 HP
Old Dec 6, 2008 | 07:37 PM
If your stock running the stage one map, with regular gas you will receive between 10-15hp (All cars are different), you will notice more torque then hp, Each mod you have makes a significant difference and with the right mods and stage 2 map and some higher octane gas you can get 30+ easy. However the biggest differences will be with a super or turbo charged car. In which case you can receive alot, however this will only work properly with a custom tune if you go super charged or turbo.
Dont forget you can always easily tune this to fit your current set up better then any Stock map will ever be.
Old Dec 9, 2008 | 12:19 PM
Bring it up.
Old Dec 11, 2008 | 05:27 PM
  #30
Bump It Up!
